Question about Xerox Phaser 8500/DN Printer
ERROR MESSAGE What is an error 07,010.43:40732? Thanks.
    President:
  • 2,072 Answers
That is a print head tilt/movement fault.
Normally one of two things occur.
If you remove the left side cover, ( looking from the front of the machine) you will see about 2/3rd of the way back on the lower portion of the frame, a stainless steel block, about 1 inch by 1 inch. Often times spill over ink from the print head or excess tray builds up in that print head block. You can remove it, normally takes some locking pliers to free it. Clean it well. I normally soak them in hot water to soften the ink, and also clean the shaft it slips on, and remove all the looks ink you can in the area.
The second most common problem is if you had a power failure or you shut the machine down wrong, the print head wiper blade will tack to the print head. To fix that, you have to remove the left and right covers, then the ink loader ( where you put the in sticks). It is just held in with two plastic tabs and a couple of connectors. Once you remove the ink loader, you will be in the print head/drum area. The blade is a pinkish color between the drum and print head. Carefully release it from the print head then when you have the machine back running, run the eliminate stripes and the smears programs.
You could have a bad wiper blade clutch, but 90 percent of the time the block or sticky blade is the problem.
Let me know, we can go from here, but I very strongly suspect you will fix it with one of those two items.
Posted on Jan 28, 2009
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
I am geting printer error message 54.18
Hi,At printer start, receive the following message: PRINTER ERROR 54.18. According to the HP error code message reference, this is a black cartridge sensor malfunction. Cleaned the sensor contacts, replaced the cartridge and rebooted; same error. Is there another fix for this?
Thanks for using fixya.....
Oct 25, 2010 | HP LaserJet 5550 Printer
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
Error message -40402
Try reinstalling it. some files have been deleted or corrupted.
Thanks
Rate me if my information is helpful.
thanks
Mar 13, 2009 | Yahoo Messenger
Error sending text messages from my computer to my friends cell
It is an internet problem as it seems. Normally you can send messages to only one mobile once if the reply comes than you can continue chatting. But as it is giving you any server error and if your internet connection is running than try to go to the preferences of the yahoo check the connection it is using. If it is using the same connection as your browser.
Thanks
If you like my advice rate me thanks.
Mar 11, 2009 | Yahoo Messenger
Cartridge error
i have a lexmark p4350 and just recently got a eror message 1102, says consult user guide, cannot find that error message in the guide, what is it, thanks
Sep 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
System Error (-1) in my 6670
well, i have , all i do just erasing all the logs, and its back to normal again
Mar 25, 2008 | Nokia 6670 Handheld
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Xerox Phaser  8500/DN Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
