Question about Lincoln Conveyor Oven - 1133-000-A
Lincoln Impinger Pizza oven 1301 model number
Everything seems to be working fine for a while then randomly the belt will stop moving. If you pull on the conveyor it will start up again just seems to hang up. There are no noticeable spots where it is catching on something. Have taken the conveyor out and cleaned it as well as the inside.
Thank you for your time,
Bill
  • Anonymous Feb 12, 2009
    I just bought this oven to back up my Lincoln 1000. I haven't had it a week yet and am seeing the belt stop randomly with no appearant pattern as to why or when.
    HELP????
  • adtarang Sep 17, 2009
    blower is on thermstate light is on but no heating
Hi,after i switch the oven on ( lincoln impinger 1157 ) the small flame and the big flame comes on and with in 3 second goes off again,i have checked the flam sensor ,air switches,relay,air blower but still same problem, anyone got any ideas? thanks Kamran
Posted on Dec 14, 2009
    Scholar:
  • 81 Answers
Brushes in the motor can cause this also the drive speed pick up being dirty can cause this problem. The pickup is the mechanism that tells the motor control how fast the motor is going, it reads either a disc or a magnet on the top of the motor. This should be clean and the pickup should be about the thickness of a credit card away from the magnet (if a magnet is used).
Posted on Jul 11, 2009
    Problem Solver:
  • 12 Answers
A little late, but it can be a lot of things the 1000 and 1300 are completly different. More input and I'll try to help if you are still having problems.
Posted on May 25, 2009
We had that problem and found the belt was slipping on the track. We removed 1 or 2 belt links with needle nose pliers to tighten the belt and had no further probelms.
Posted on Mar 29, 2009
This could possibly be caused by the brushes in the conveyor motor. they might be worn out or sicking.
Posted on Feb 28, 2009
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Apr 29, 2014 | Lincoln Ovens
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at maugoro@yahoo.com
Feb 05, 2010 | Lincoln Ovens
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
Lincoln Conveyor Oven - 1133-000-A Logo
2,651 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
