Question about Toshiba TEC B-472 Thermal Label Printer
Only prints 9's
Whenever I pick a label to print, it looks fine on the screen but all digits and text come out as 9
    Champion:
  • 254 Answers
This is a aracteristic of demo version of the print software not a printer problem
Posted on Sep 16, 2011
I loaded the windows update driver and connected my PSC 2115 all in one printer. It prints text documents and the test page without any issues. It displays images in print prieview but won't print them.
You need to get the manual for this printer, it has a printing language all it's own. The encoded text tells it where to put the bar code on the label, how to encode it, what text to put under it, etc. It's looking for a specially designed print file that's plain text. There may be a way to turn that off and turn it into a bitmap printer, but you would need the manual for that.
Nov 23, 2010 | Zebra 105SL Thermal Label Printer
Label printing
you'll need new drivers for vista...get them here
Mar 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Labels not lining up corectly
Go to printer options and select "Fit To Page"
May 24, 2017 | Microsoft Office Standard 2007 for PC
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
After calibration the first print is fine.. 2nd print to label seems to backup into the printer before the next print ..result in text missing info... workaround is ..I need to pull the label out a little...
Sounds like you are printing from Zebra Designer, if so all you need to do is click File/Printer settings/Advanced setup/tick the box marked "Top of Form Backup" OK, and then save your label file.
Nov 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I am working with 2 Toshiba SX8 thermal printers. The text recently started shifting downwards for no aparent reason on both printers. Jobs that I have printed fine the last couple weeks have sudenly...
several reasons may cause this problem.
-On Tec printers, the height of the labels must be the most precise possible. You must include the gap height in the command
{D0350,1000,0320|} for la label size 100 mm and 32 mm high and 3 mm interval. If this information is missing, the printer may work correctly for some time and suddenly you'll have your phenomenon.
- You may have a label stuck under the sensor.
- You may need to recallibate your sensors.
- the correct sensor is not selected
Sep 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Only prints ''smeared labels'' with no text even remotely recogniza
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Feb 19, 2009 | Datamax E-Class E-4203 Thermal Label...
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
Toshiba TEC B-472 Thermal Label Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
