Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak aio home center
I have my kodak esp7 printer connected to a wireless router and everything works fine except now when I open the home center I have all the Icons but when I click an Icon I have no printers to choose from and it tells me to get help connecting to my wireless network. and another problem is everyday I have to clean the heads. is this normal?
    Sergeant:
  • Kodak Expert
  • 285 Answers
I dont have an answer to your first problem, but i do to your second
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free.
by the way, the cleaning heads issue is normal since the cartriges don't have printheads
Posted on Jan 28, 2009
100-2070 home center
Right click on the KODAK AiO icon - select properties. Click on the compatibility tab and check "run this program in compatibility mode for:" and select your operating system. Then check the box for "run this program as an administrator". Click apply and run your KODAK AiO Home Center program. No more 2070 error.
Jan 26, 2012 | Kodak Office Equipment & Supplies
Toshiba laptop running Vista won't connect to Kodak ESP7 Printer
Connecting Kodak ESP 5250 Printer to Windows Vista PC through Wireless Network.
After following the initial steps in the Start Here booklet that comes with the printer (unpacking, connecting power, inserting print-head/ink-cartridges and calibrating) I connected the printer to my computer through the USB cable as per page 7 of the booklet because I needed to get started printing quickly. Two notes: the USB cable supplied was pretty short and wouldn't work with an extender-I'm not sure why-so I used an older, longer one I had. And as with most printers, do NOT connect the USB cable right away. Start the software installation first and only connect when it tells you to. I downloaded the latest version of the printer software from Kodak, but I don't it made much difference and it was a very large download.
To go wireless the first thing you need to do is get the printer onto your network. Do this by turning the printer on and pressing the Menu button. On the printer's LCD screen cursor down to and select Network Settings then WiFi Setup Wizard. At this point you need to have some familiarity with your wireless router and the security routine(s) you are using. Pages 8 and 9 of the Start Here booklet walks you through these steps. I don't used data encryption (probably should, but too lazy and also wonder if it will reduce transmission speed), but I do use MAC filtering to keep unknown devices (like my neighbor's computers) off my network. The booklet does not address this. If you are not using data encryption (I think WPA-2 is current the standard) you should at least use MAC filtering. If you use data encryption you don't really need MAC filtering, but some folks use both. MAC filtering works like this. Every wireless device has a unique MAC address that is put in when manufactured. It is permanent and not shared with any other device in the world. If you turn MAC filtering on in your router configuration, then you must enter into your router a list of all devices that you want the router to allow onto the network. Anything that is not on the list will not be allowed on. This gives you absolute control over who/what gets on your network. But unless you also use data encryption, the data transmitted between your computer and your router could possibly be picked up and viewed by others. This would require some pretty special equipment, not something your neighbors could do with their home computers, but it does exist. The other thing is, with some devices it is a bit of a struggle to find the MAC address. I had a hard time with my netbook that uses a UNIX operating system, but finally got it. If you are using MAC filtering you can find the printer's MAC address by going to Network Settings then View Network Configuration and scrolling down to the bottom. Anyway, once your printer is truly connected to your router you should see a blue WiFi indicator at the bottom right of the printer's main screen (the one with "Kodak" in red letters in the top half of the screen). If you are still in the menu screens you can go to the main screen by pressing the Cancel button on the printer.
Connecting the printer was the easy part. Getting the computer to talk to it is not so easy. If you connected by USB first, unplug the USB cable. If you were connected by USB you already have the software installed. If not, now's the time, either by disk that came with the printer or by download from the Kodak Help Center (just search this term). Be advised, the download is large and takes some time. The software will install the Kodak AiO Home Center on your computer. After you install it, it will be found in the Kodak folder on the Start Menu. No indication is given, but at the same time AiO is installed the Bonjour Printer Wizard is also installed in a separate Bonjour folder on the Start Menu. More on this in a minute. If by some strange quirk of fate your printer will now accept documents from your computer through your network that's great. Mine didn't so I finally called Kodak's printer support number and after a very short wait (good on you, Kodak!) I got the following help. The first part was to make sure my computer and printer could talk to each other through my wireless network. This was done by "pinging" the printer from the computer. You will need the printer's IP address which can be found under View Network Settings (see above). It consists of 4 numbers separated by periods. The numbers can have anything from one to three digits each. Once you have the IP address available, click on the Start button at the bottom left of the Windows screen. Then click on All Programs. Open the Accessories folder and start the Command Prompt. This should open a box with a black background with a command line ending in "
Jan 11, 2010 | Computers & Internet
Kodak aio home center experienced an exception and cannot continue Error 1- 2010 What is this?
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Oct 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open - getting Error Code 1-2010
uninstall the printer software complettly than reinstall it.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak software not talking to esp7 printer with vista 64 os
open the Kodak all in one home center on your desktop and click on Connect your kodak printer or install your kodak printer. if the printer drivers are installed,go to printers in control panel and set the Kodak printer as default. If not resolved,Download latest version of software that is 4.2 from www.kodak.com.
Aug 07, 2009 | Office Equipment & Supplies
Kodak printer not detected
Check in your Control Panel (Printer & Faxes) if the printer is OFFLINE. Via wi-fi network, obtain the IP Address both of Printer & your computer.
Aug 06, 2009 | Kodak ESP 5 Printer
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Aio Home center will not open up to scan.
  1. Is your drivers properly installed?
  2. Use Paint in windows and try to aquire a imige from there,
  3. Else reload your driver
  4. Still not working reload your O/S windows
Dec 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Unhandled Exception message with new 5300 AiO
go to c:\windows\system32\kodak and check for kds_aio5000 and inside that you should have 1 folder and 1 file. the folder name is lib and the file name is ekaiowia.dll. inside lib folder there are cct.ekpgct and hippo.dll. If not then uninstall the home center and then go to www.kodak.com/go/clear and run it then install the home center from www.kodak.com/go/downloads and choose the appropiate product.
Jun 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
207 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
