Question about Garden
WON'T START EVEN WITH NEW FUEL AND A NEW PLUG
TORO 826 LE SNOW BLOWER, ONLY USED THREE TIMES AND IS ELECTRIC START
  • Jeff Hord Jan 28, 2009
    HAVE ALREADY PUT IN NEW PLUG, DRAINED FUEL AND REFILLED SAFETY KEY IN IT, OIL IS CLEAN AND FRESH AND FULL, APPARENTLY NOT GETTING ANY SPARK AT ALL! CAN THINK OF WHY, IT HAS ELECTRIC START ALSO!
  • Jeff Hord Jan 29, 2009
    I'LL GLADLY GIVE YOU A RATING...JUST WANT TO GET THIS FIXED...IT APPEARS THERE IS NO SPARK AT ALL...EVEN WITH ELECTIC START PLUGGED IN...WHAT COULD THAST BE?
5 Suggested Answers
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
SOURCE: Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Posted on Feb 01, 2009
rwvanlue
  • 486 Answers
SOURCE: How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
Posted on Dec 04, 2009
  • 173 Answers
SOURCE: I have a problem starting my Toro Power Max 828 LE
Take a spray bottle and spray gas into the carb and see if it starts.If it starts you more than likely have a carb problem. first thing check and make sure gas is flowing to carb. Take the line off at the carb and see if gas flows through the line. If you have gas to the carb you will have to take carb off and clean it out and check to see if float is stuck closed.you might want to put a rebuild kit in it while it,s apart.
Posted on Dec 17, 2010
I have a toro 826 snowblower and i cant get the thing to start there is no primmer bulb i dont know if the choke lever goes down to start?
https://www.toro.com/en/homeowner/snow-blowers/power-max-826-oe-37772
Click on parts and manuals then select the year that it was made and then you can download the operators manual.
The most common cause of failure to start is bad gasoline, Gasoline cannot be left in the fuel tank without a stabilizer added to it. It goes bad after about 1 month.
Nov 20, 2016 | Garden
Which oil to use for toro model 826 le
Hello, Here is the oil and i am putting the website for you to have the specs for the engine on it too. The oil to use is 26 oz. (.8l) 5w-30 or 10w / API SH or higher. Toro
Dec 11, 2014 | Toro Garden
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
My Toro snow blower requires leaded fuel. Can I
I would not reccomend it. just buy some lead additive at any auto store or automotive department & mix per the directions.
Nov 15, 2009 | Toro Blowers Rake and Vac - Electric...
Snow blower spark plug replacement
I would check it at the start of every season and clean it. If you note that it seems to be running rich and might have fouled the plug, you can always pull it and check it again. Probably not a bad idea to check it before you put it away for the season. As for replacement, it depends on condition. I would think that you should get two or three season's use out of it before needing to replace it, at least.
Jan 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
