Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Shut down computer restarted hard is not listed or doesnt read
Restared the computer and will not reconsie the hard drive now turns on find light is on and the computer wont find it help please
Hi
This Danish Khan
i am gonna solve out ur problem cetrtain
first of all u must check out ur Data cable which is called as a interface data cable
which attch ur hardisk to ur motherboard.lets change it by new one.still it show same error thn
u change ur hardisk jumper setting,whish is printed on hardisk.when u takeout ur hardisk from ur computer then u will find a jumper settings of hardisk over there.
i sure that u problem will be solved out by these steps.
Posted on Feb 02, 2009
Emachine E528 Laptop is saying a disk read error occured push ctrl+alt+delete an it will restart
The error that you are getting indicates that the system is not able to detect the Hard Drive. We would need to confirm if the Hard Drive is detected in the system BIOS or not. For that we would need to turn off the computer. Turn on the computer and start hitting F2 key to reach BIOS. On the First page of BIOS it should show you the Hard Disk Drive with name and Number. If it shows all drives and none or not detected then it means the hard drive is not getting detected by the system. If you can open the Laptop and reach the Hard Disk Drive you can try to re-seat it to see if it gets detected. If it still remains undetected, Its time to replace the Hard Disk Drive.
Please try the above steps and get back for any further assistance or clarification
Aug 05, 2012 | Computers & Internet
My E725 won't turn on. Battery full. Was restaring it after uploading wireless softwre. Took forever to shut down.
I take it you are talking about laptop. Try to turn it on with adapter, there may be problems with battery itself. If it doesnt work and laptop doesnt turn on as in nothing happens, no sound, no light at all and so on, you need to use technical support. It is VERY likely you can't handle repairing it on your own. Need to open it up and search for hardware problems.
Apr 08, 2011 | Computers & Internet
Cd rom is not read any cd
bad optical disk drive or bad connection restart your computer open bios and see if its showing your disk drive there... if not then you could turn it off remove the drive turn on the machine let it boot then shut it down and restart it if it still doesnt show up you need a new drive... if it does show up and still not reading cd's or if it was there all along you could have a bad odd lens which i would say just replace your cdrom drive
Nov 18, 2010 | Acer Aspire One PC Notebook
How to reboot computer
hi
  • Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
  • Step 2 Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
  • Step 3 Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
  • Step 4 Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
  • Step 5 Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
  • Jul 04, 2010 | Compaq Pavilion ZT3280US Notebook
    My hard drive wont connect, and the computer doesnt recognize it.
    hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
    Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
    Hi When I try shut down the pc Windows XP will close leaving the power supply, cpu,fans, usb still running To shut down the pC I have to turn off the power switch at the rear Please help
    This issue also cause by a hard drive errors, check your hard drive for errors. In My Computer window, right click Local Disk C select Properties, go to Tools tab, click Check Now button, put check on Automatically Fix Errors and Recovery of Bad Sectors, then restart your computer to run the check disk operation.
    Also read this solutions regarding about Windows XP Shutdown and Restart Troubleshooting
    http://www.aumha.org/win5/a/shtdwnxp.php
    Jan 26, 2010 | Abit IT7-MAX2 Motherboard
    Cannot read disk
    "A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
    Dec 04, 2009 | Dell Dimension 2400 PC Desktop
    Computer does not boot up completely -shuts down by itself
    for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
    Here to Help
    Shaun
    Nov 24, 2008 | Computers & Internet
    Windows
    hard drives dont read cd's
    does the door close?
    if not close it.
    1)left clik my computer
    2)double clik the cd rom drive, making sure theres a disk in it.
    3)right clik on my computer
    device manager
    look for a yellow exclamation point or red X where the cd-rom is.
    high light the cd-rom
    right clik
    uninstall
    windows will detect and re-install the cd-rom drive.
    try a cd
    if that doesnt work update windows
    also buy a cd-rom cleaner at your local electronics store
    clean the drive w/th cleaner
    try a cd
    if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
    Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
    Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
    127 people viewed this question
    Top Western Digital Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Marcin
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
