Failed memory test after adding memory
I added a VDATA Memory Expert DDR400(30 1g X16
s/n608jh (vdbgc1a16) The other number on the stick is MDGVD6G314750B1E09 in the thrid slot. When I try to start up, there is a voice message saying "System failed memory test".
I've tried inserting the card both ways,but neither way works.
  • 56 Answers
NEED TO CLEAN THE LEAD ON THE MEMORY WITH SCHOOL PENCIL#2 ERASER, DO NOT TOUCH LEADS THAT PLUG INTO THE MOTHER BOARD.
MOTHERGOARD CONNECTOR MAY HAVE DUST OR FORIEGN METTERAIL IN THE CONNECTOR, USE CAN OF AIR IF NO TRY PAINT BRUSH,
PUT NEW MEMORY IN FIRST THAN OLD OR
OFFSET THEM ONE NEW ONE AND OLD ONE AND SO ON.
CANDYMANGANDY
Posted on Jan 28, 2009
How to enlarge RAM capacity
You must either buy larger RAM SIMMs that are compatible with your system, or buy more of what you have (if there are more SIMM sockets in your system.
Dec 03, 2015 | Computers & Internet
Gateway NE56R31u will not boot after memory upgrade
sounds like you have either a bad module or it is not the right kind , if you have ddr2 memory stick and you have added a ddr3 it will not work or you have exceeded you systems memory capability it will not work .
Jun 15, 2014 | Gateway NV5378u Notebook
1-3-3-1 beep at boot on toshiba satellite
If the Toshiba satellite uses the Phoenix BIOS, then the 1-3-3-1 beep code indicates a memory problem. The specific problem the BIOS saw on the self-test is 28 Autosize DRAM.
It could be a problem with the CMOS battery. You can try replacing this coin battery. You can also try resetting the CMOS. For some computers, you can do this by removing the battery for 20-30 minutes. Other computers will have a CMOS jumper that you can use to reset the machine. I'd need the model number to check the CMOS reset.
More likely one or more of your RAM is incompatible or damaged or the motherboard RAM slots are damaged. If you have two memory sticks, then if they aren't the same speed or type, this error can occur. Remove the RAM and test one stick at a time. If you recently added memory or otherwise upgraded your RAM, test the old memory and the new separately.
Sometimes, you can accidently get the wrong memory. Some computers can only support RAM with memory modules on one side of the memory stick. Newer memory often has memory modules on both sides. (This applies only if you recently upgraded the memory. You should use a memory configuration tool to check the supported memory for your machine. Each memory manufacturer has one for their memory.)
If this error occurs with the original memory or each memory stick separately, you will need to test the memory in another computer or get new memory to test in your Toshiba. That will determine if the memory was bad or if the motherboard is damaged.
If you add a comment with your computer's model number and the details of your memory for the system, I may be able to provide more specific suggestions.
I hope this helps.
Aug 07, 2011 | Computers & Internet
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
471 people viewed this question
David Payne
David Payne
