Question about Breville Die Cast 800ESXL Espresso Machine
Is Durgol safe to use with Breville 800esxl?
Breville tells me to use white vinigar to descale my espresso machine but in order to speed up the proccess I purchased some Durgol. Now after reading some reviews I am unsure if it is safe to use as it may damage the pump. I am puzzled as this product was designes to be used for espresso machines.
Replace pump breville 800esxl
How to replace the thermostat in the breville 800esxl machine
Nov 07, 2013 | Breville Die Cast 800ESXL Espresso Machine
How do I put hte vinigar in the Breville one cup to descale?
Hi. Dont do that. That wont do anything to help the machine. Need proper descale solution. Bicarb soda at worst can be used. Dazza
Sep 23, 2011 | Breville BKC600XL Coffee Maker
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Need to know the correct tamper size for a Breville 800ESXL ??
I found this one on ebay:
http://cgi.ebay.com/TERRYS-ESPRESSO-COFFEE-TAMPER-50-55mm-DUAL-SIDES_W0QQitemZ330319118719QQihZ014QQcategoryZ20671QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the 50mm side works perfect for the Breville 800ESXL and the material matches the machine. It takes up less space than the original spoon/tamper combination and sits nicely on the warming surface when not in use.
Mar 29, 2009 | Breville Die Cast 800ESXL Espresso Machine
Need a new cupfilter number 2 hole blocked and cant be cleared
trie and put the cup filter in descaling solution a couple of yours and then clean it extremly good. this might clear out the blockage in the filter.
Jul 15, 2008 | Breville Die Cast 800ESXL Espresso Machine
Frothing of Milk
I simply use a needle on mine. I don't believe the upper section gets blocked unless you have hard water. Then you will have to go with a descaler solution.
Jun 27, 2008 | Breville Die Cast 800ESXL Espresso Machine
Wont power on
try runnig white vinegar through the machine to clean scale. there are probably descale solutions that you could buy as well but for mt the mild acetic acid in the vinegar helped to free up my valve.
Apr 28, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Feb 24, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
88 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
