Question about E-Machines eMachines Desktop PC
My emachine t2882
I have a t2882 i need the schamatics for the power supply and all the drives are hook up
  • 21 Answers
Try this : See if you can find your motherboard model number. If so, type it into Google, go to the manufacturers site and download a manual which should have the wiring diagram you require.
Posted on Jan 28, 2009
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is:
This site will explain about the 24 pin connector from the power supply
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
I have a t2882 emachine it won`t turn on light on frount is on but won`t turn on
Check the monitor connection the pc or you may have to buy a video card for your pc.
Jul 18, 2009 | E-Machines T2882 PC Desktop
Computer worked fine, unhooked it to hook up a new one, decided to hook the emachine back up to play games on, got it hooked up but it won't come on now. everything is hooked up right, i opened it up and...
make sure you hook everything with a little force especially the memory until it snaps back into place. same goes for all the cards. care should be give to the cpu, nice and easy. make sure your power supply is potential enough or has not gone bad. The MB can give a green light but there could be too little energy for the whole system.
Mar 27, 2009 | E-Machines Emachine T5026 power supply **...
Not getting power on my t2882 e-machine.
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at or ring me on 07926-106150
Mar 19, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
The main connector to the power supply has to go into the motherboard. Its a rectangle shapped male connector that is on the end of the power supply that plugs into a rectangle female shaped connector on the motherboard. There might also be a shorter square male 4 pin connector at the end of the power supply that should connect into a 4 pin female connector on the motherboard.
After this then you'll want to plug the other connectors into any cd-rom, dvd-rom drives you may have. Same for a floppy drive if you have one. Also make sure your hard drive is hooked up. The connectors that you plug to these devices can only go in one way so no worries about hooking it up improperly. Hope this helps.
After all this, turn on the computer and then after you boot up into windows, make sure you go into my computer and verify that all your drives are being shown in there.
Jan 28, 2009 | E-Machines eMachines Desktop PC
Are the pins from the switch to the motherboard connected properly?
Could be a faulty switch on you case. T
ry shorting out the two power on pins (on motherboard) with a screw driver but be carefull not to touch anything else with it!! :)
hope this helps?
Jan 06, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
95 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
