Question about Whirlpool LER8648L Electric Dryer
Whirlpool electric dryer not drying
I have a Whirlpool electric dryer - model #LER8648LW0 (approx 5 year old) It does not get heavy usage, as I live alone and do approx. 1 load/week.
The other night I ran a full load and it dried perfectly. The next afternoon I threw in a damp queen size sheet - went to check on it and after 15 minutes it was still damp. Turned the selector knob and nothing!
Threw the breakers a few time - still nothing! The interior light is working so it is getting power.
  • 4 Answers
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Posted on Jan 28, 2009
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
We have a Whirlpool WED5821 electric dryer. The dryer is only 3 years old. When it is drying it is making a high pitch noise. When it first started it would be heavy loads. Now it doesn't matter the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Whirlpool WED5821S Electric Dryer
I have a Whirlpool model LER8648LW0 that is about 8 years old. It gets a lot of use. It used to dry well, but now takes almost twice as long to dry an average load. Towels take about 1 1/2 hours on high...
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil is ok, then you want to check the thermistor/thermostats. Remove the wires and tape them together one at a time with electrical tape and turn on the machine and see if it heats up ok...if it does then replace the thermostat/thermistor that is bad.
DO NOT LEAVE THEM TAPED TOGETHER. BECAUSE THIS BY-PASSES THE SAFETY OF THE MACHINE.
Good Luck,
Hope this helps
Oct 13, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Apr 26, 2009 | Whirlpool LER5636P Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Whirlpool Dryer Model # LE7680XSW1
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
Jul 30, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Whirlpool LER8648L Electric Dryer Logo
383 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
