Mitsuba DV304 Flash Media Camcorder Logo
Sean McDonald Posted on Jan 24, 2013
Where do i find the battery charger for my mitsuba dv304 lm
I have a dark grey 3.7V 900mA batterry. i need the charger it slides into
2 Related Answers
Anonymous
  • Posted on May 27, 2010
SOURCE: Mitsuba DV304
i need a user manual for my camera ,can i down load the manual for free?
Anonymous
  • Posted on Oct 14, 2010
SOURCE: How do I turn the flash on my camera? It is a Mitsuba DV304.
You move the joystick to the left to enable the flash!.... took me forever to figure it out lol.... hahaha
Mitsuba DV500 does it need a good battery to turn on? I plug to charger light comes on but won't turn on the battery is bad. If I buy battery & camcorder is bad can't return battery there bit pricey
I would suggest that to get a diagnosis of the fault that you take it to a reputable camera shop and get some idea of the problem
preferable a shop that sells that make of camera
Need battery charger
You could try to buy a charger from Polaroid, but not only will that be expensive, it could be almost impossible to find the same one you had.
I do use two universal chargers, for my camera's. mine are from GP, but I'm convinced there are other brands to. One charger, I need to adjust the spacing between the contacts, but not tree are chargers, that don't need any adjustment. The voltage needed, is found by the charger, the moment you connect the battery.
Because I do have a Kodak (3,7V) a Canon (3,7 volt) and a Nikon (7,2 volt) I have to adjust, but all batteries are charged every time.
When traveling I only need to take one charger for 2 or 3 different cameras. Next camera? I can leave the charger in the box.
same could go for you too.
2helpful
I've bought 2 different Sd cards for my camera, and when I put them in, my camera locks up. It works fine without the Sd card.
New memory cards are to be formatted before its use.So please format the card in the camcorder itself as described in the User manual and then you can use it as usual.Please don't forget to rate me if satisfied.Good Luck
2helpful
How long do you charge the li-ion battery on a Mitsuba HDC-8800?
It usually takes around 16 hours for the first charge. Then a few hours after that. When you charge the battery and it is fully charged, the light on the charger will change from red to green. I would not recommend charging it any less then that amount of time as it will cut battery life back dramatically over time.
6helpful
3answers
Mitsuba DV304
1helpful
6answers
Manual
I have lost my digital photo navigator by reinitializing my mac computer and misplaced my digital photo navigator Ver.1.5 where can I go to get a download?
2answers
Mitsuba mv300l
i live in wshington dc and i need a charger when i can find it?
i have a mitsuba camcorder panasonic
Top Mitsuba Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
