Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid dishwasher will not drain completely model kuds25shwh1
I have a dishwasher that seems to work well, but after the wash cycle is complete, I discover a small amount of water inside, above the circular drain filter. This has been happening in the last dozen or cycles, the water is cloudy and does not drain completely. I have tried an additional rinse cycle to see if it clears out, but to no avail, only the water gets clearer. I have checked the drain pipe and appears to be clean at the spot where it dumps into the garbage disposer. Any ideas before I start pulling the whole unit out to look under and beyond?
  • 1 more comment
  • Peter Vega Feb 05, 2009
    Same problem, now it won't drain at all.
    Same problem, but now it does not drain at all.
  • Anonymous Feb 24, 2009
    If you push the cancel button, the problem seems to go away for a while. This is not a solution, but a quick fix to another anoying Kitchenaid problem. The help I got from KitchenAid was
    - new motor for my hood,
    - dishwasher - reconnect some drain pipe to get the machine going for the 1st time (1st week)
    - stove - change the door and glass (product came with a crooked door and the glass broke trying to refit the door.( 1st week)
    -fridge - changed the magnet lining (1st week)
    The solution - DO NOT SUGGEST TO ANYONE TO BUY AMERICAN. Nobody needs these anoying problems.
  • 332 Answers
There is a plastic cover in the back over the drain under the dish tray,, pull out the tray and in th back of the dish washer there you will look down and see a small strainer that is plastic, you will need a 1/4 inch nut driver to remove the cover,, after you remove it there is a couple of pastice peices to take out that are just laying there, remove them and there is a small blade that is there to help cut up food that has been left behind on the dishes,, you can remove this and under it you will find the drain hole,, clean out any debris that is in there, if you have to you might want to take tha bottom cover off the lower front of the dish washer take off the drain hose and flush water thru,, adfter this and then reinstalling everything the way it was, run the dish washer if it still has water sitting in the bottom it is time to get a new pump, it is bad and not pumping,,, you may wish to have an appliance person out to tackle this job,, good luck
Posted on Jun 30, 2009
  • 250 Answers
Check to see if the drain hose is excessively long. If it is, either trim it as short as possible and install a dishwasher air gap, or arrange the hose in such a way that it goes up as high as possible, and the majority of its length is sloping down towards the disposer. My guess is that the hose fills up, the drain pump cuts off, and the water runs backwards down the hose into the dishwasher. You may also be able to find a one-way check valve that will fit the hose at your local hardware store. Again, install this valve as close as possible to the dishwasher.
Posted on Feb 24, 2010
I have a Kitchenaid dishwasher model KUDC10IXWH0 that has a problem. It will not complete the wash cycle. It runs for about 15 minute and then goes to cancel/drain cycle. The code on it is 6-1. Any...
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
I am going to ask you to do a diagnostics and then get back to me.
Search:
4317364_kad-9_kitchenaid_drawer_dishwasher.pdf
Dec 23, 2014 | KitchenAid Dishwashers
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Dishwasher not draining completely-suds left
Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Residue is left behind after cycle is complete. Dishes looks dirt
if dirt is not being washed away it is most likely you have a clogged screen before the waste tube. Depending on the model. Dismantling the dishwasher takes place inside it and under it where the motor is located.
Mar 13, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
3,069 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
