Question about Nickelodeon SpongeBob SquarePants Multimedia Player
Test communication Hi Just checking to see if I followed your instructions correctly. Safenude
  • Bernie Thames
    Bernie Thames Jan 29, 2009
    That's what I have been doing. Some of the questions are so bad, you have no idea what they want. I use the clarification alot.
    Safe
    Guru:
  • 859 Answers
Welcome to FixYa and give yourself some time to get comfortable just answering questions. Its often more wise to ask a clarification than respond to a poorly constructed question.
Most people if they really need help will come back and rewrite their questions.
And give yourself some time to grasp how things actually work here and then ask in The Lounge.
Worldvet
Posted on Jan 28, 2009
I am getting an F 11 code. I have followed the instructions in the manual to reset/cancel twice then set to the spin mode to drain any excess water. This has not worked. It counts down then completely...
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Duet service manual and repair photos are HERE
Feb 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I can't log in to configure my router. I tried loging in using 192.168.1.1 but its not working an I don't know why. Help please
You may need to double check if the router is giving the correct IP address. You can this by doing the following:
1. Go to Control Panel.
2. Got to Network Connections
3. Right click on the the connection that you are using to connect to the router, wired or wireless. Then go to Status.
4. Go to the Support tab. Check the IP address and the Default Gateway, it's the Default Gateway that will tell what is the correct router IP address.
After you verify the correct IP address, you test if your computer is still communicating with the router. To do this, do the following:
1. Click Start go to Run and type "cmd" and then hit return.
2. In the command prompt, type this command "ping 192.168.1.1" or ping whatever IP address you will see in the support tab for Default Gateway.
You should get four replies if your computer is communicating with the router. If you not make sure that you disable the firewall/s in your computer. You can also use a different computer.
Jun 19, 2010 | Computers & Internet
I am attempting to link MS outlook 2003 to Juno. I have followed the instructions provided and when I test account settings I get the following message: Send test email message: unable to send test...
ok make sure that your server pop link and other details are placed in MS out look account settings as fine while creating it otherwise you would get the same. e-mail id routing is important once if your mail-id is fine.
Dec 14, 2009 | Microsoft Office Outlook 2003 for PC
How do i install my quickcam communicate STX
Hello my friend, kindly follow the following steps:
1. Insert the CD driver of your Logitech Quickcam
2. Goto the CD/DVD drive and find the setup.exe and run it.
3. Follow the installation guide wizard to complete the installation process.
4. If the system requires to restart your computer then restart it otherwise try to test the Webcam to see if you have installed the right and correct driver.
Thanks
Jul 28, 2009 | Logitech QuickCam Communicate STX Personal...
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
I have HP deskjet F4288 ,print is not comming.
Try printing a self-test page... to do that please follow below instructions...
Printing a self-test page Follow these steps to print a self-test page from the control panel. Make sure paper is loaded correctly in the product before beginning the procedure.
  1. Press and hold the power button (c01346625.gif ), and then press the cancel button (c01361518.jpg ).
  2. Release both buttons. The self-test page prints.
Thank you.....
Jan 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
I can send a fax, make copies, but cannot receive a fax on my HPL7590. Help
hi tbacsa02,
this was a solution i posted earlier with someone that has the same problem like yours.
follow this few steps;
first can you try this;
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test does the following:
• Tests the fax hardware
• Verifies the correct type of phone cord is connected to the device
• Checks that the phone cord is plugged into the correct port
• Checks for a dial tone
• Checks for an active phone line
• Tests the status of your phone line connection
The device prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test.
To test fax setup
1. Set up the device for faxing according to your particular home or office setup instructions.
2. Make sure the ink cartridges are installed, and that full-size paper is loaded in the main tray before starting the test.
3. From the device control panel, press Setup.
4. Press right arrow to select Tools, and then press OK.
5. Press right arrow to select Run Fax Test, and then press OK.
The device displays the status of the test on the display and prints a report.
6. Review the report.
• If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause problems faxing.
let me know.
Jan 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
SuperPen (Wizcom) does not Communicate with PC
Just bought the pen and I've got the same problem. I've tried 2 PCs, one with XP SP2 and the other Vista (using Vista driver from Wizcom). Both give me the same "cannot communicate with Pen" error message. I've double checked every recommendation I could find on Wizcom's website and the internet, but looks like either the cable or pen is faulty. Would be good to know if the new cable they're sending you fixes the problem.
Jan 11, 2008 | Office Equipment & Supplies
Laserwriter 12/640 PS
hello the printer paper pick-up rollers are bad. this why you caanotuse the pick tray. the solution now is to set the printer to default and clear allstuff off memory. read the instruction below: LaserWriter 12/640 PS: IBM PC or Compatible Troubleshooting This article explains IBM PC or Compatible Troubleshooting. A message on the screen says the printer can't print. If you get such a message, try the following steps. Make sure that the printer is turned on. Check the network or parallel cables. Make sure that the PostScript printer driver has been installed. Nothing is printed; no paper comes out of the printer. If you don't get any response from the printer when you try to print a document, try the following steps: Check the Installed Printers list to see that your printer is selected. Try printing the document again, but choose Download PostScript Error Handling in the Printer Setup PostScript Options dialog box. Check the Paper Out light. If it is on, add paper and replace the paper cassette. If it is blinking, make sure the paper cassette is securely in place. Check for a paper jam. Check the printer cables. Check the position of the port communication switch. The port may have been turned off or the Interpreter settings may not be correct. Reset the communications settings to their factory default values by setting the communication switch to the Reset (out) position. Turn the printer off and back on again. Set the communication switch to the Normal (in) position. Turn the printer off and back on. Check the startup page. Reinstall the printer driver. For Windows 95 users, check the following additional item: Open the Printer folder, select the printer, and click Properties. click the PostScript tab and click the Advanced button. Make sure that ASCII data and "Send CTRL+D after job" are selected. For Windows 3.1 users, check the following additional item: Open the Printer Control panel, select the printer, and choose Setup. Select the PostScript tab in the Properties dialog box. Make sure that Protocol Options is set to Default if using the parallel port, or None if printing via NetWare. Sometimes Printing the First Page Takes Longer than I Expect The LaserWriter 12/640 PS automatically goes into an energy-saving mode after it's been idle for a while. When you print while it's in this mode, the printer takes about a minute to warm up before it can print the first page. The printer is properly connected and configured, but printing is garbled or displays unwanted characters. Check the communication switch and make sure that the Interpreter is set to the correct value. If you are printing a PostScript document, the Interpreter mode should be PostScript or AutoSelect.
Aug 08, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Nickelodeon SpongeBob SquarePants Multimedia Player Logo
76 people viewed this question
Top Nickelodeon Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Nickelodeon Toy Expert? Answer questions, earn points and help others
