Question about Tech Solution TS-4500 Shredder
Techsolutions ts4500 quit running while shredding and won' start
The green line is on but the paper won't activate it or the reversal switch.
I threw it in the trash and purchsed a big scissors.
Posted on Jan 29, 2009
My TS4500 works in reverse but not in shred even when the green light is on. What can I do about it?
Dear Wayne.
I tried to be a shredded service person, and I suspect your problem is inside the machine where you cannot see it.
I think the cutting heads are clogged with paper and/or bent.
I have repeatedly ordered cutting heads ( from different companies) and been told they were back ordered, because they were made overseas.
Try taking your machine all apart, and I hope your repairs are more successful than mine have been.
I finally gave up and replace them with those symptoms.
God bless your efforts.
Dec 13, 2016 | Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Tech Solutions shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
Paper shredder
The only solution with respect to safety is to order a new switch from the companuy that manufactures/sells this shredder, and mount it according to the manufacturer/sales company's instructions.
If you want to bypass the safety of the machine, just keep the cables (should be 2, + eventually a ground cable) open, or shorted, depending of the machine's configuration. Remember that this is on your or your collegaues own risk!! A shredder can easily bite your finger off!
May 19, 2007 | Tech Solution TS-4500 Shredder
TS4500 Shredder
there is one screw under the s/n sticker
May 08, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
262 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
