Question about Infinity Reference 7541a Car Audio Amplifier
INFINITY AMP PROTECTION LIGHT FLASHING FOR 5 SECONDS
I have this problem,my infinity amp lost power to the sub this morning and has worked a few times since, but the protection light is on now. it stays on for 5 seconds, goes off, then on again for 5 seconds continuously like that. if i disconnect the speaker cables for the sub, the amp clicks.
i have the power going to a power cap, then to 2x amps(1 for front speakers and the problem one for the sub) so it cant be the main power cable.if there was no power,the light wouldnt be on right? the earth is the same place as the working amp,using the same bolt into the cars metal.same remote turn on cable too. im stumped!
it's happened before, but with no assistance, started working again!
this suggest a loose wire internally?
thanks in advance for any help
    Scholar:
  • 67 Answers
I have an Infinity amp as well, and I was having the same issue for a time. The amp is protecting itself from some sort of overload. It could be the Ohms load on the sub, but I would guess not. Make sure your low pass filter is set to LP and not HP or Flat. Then check the RMS on your subs and match that to the Amp RMS. Once I did all that I found that everything worked fine, for a time. It started doing this again, and I checked the fuse and it was blown badly. It seems that the fuse setup on some of these Infinity amps is not as good as one would hope, because the charge was bridging the gap and frying out my fuses. It was like a spark would jump from one side of the fuse to the other without travelling the fuse itself, and this was causing my protect issues. I pulled the fuse, got a new one of the same rating, but I placed the fuse in with a little piece of rubber in between the 2 contacts, and then connected to the fuse block. I have not had problems since.
Posted on Feb 02, 2009
When power gets put to the amp the protection, power and clip lights start flashing and the amp puts out zero power
Check the impedance of the speaker set up. Reasons for going in to protection mode is that amp can't handle the impedance... Just incase you don't know what impedance means, it is another way of saying ohms!
Sep 18, 2010 | Infinity Car Audio & Video
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Jan 22, 2010 | Infinity Reference 7541a Car Audio...
Amp 7541a amp was working fine, Took it out of one
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 18, 2009 | Infinity Reference 7541a Car Audio...
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Jan 28, 2009 | Infinity Reference 7541a Car Audio...
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
Infinity Reference 7541a Car Audio Amplifier Logo
443 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
