Question about Kenmore 24 in. 16582 Built-in Dishwasher
Kenmore elite dishwasher takes almost 3 hours to run
Everything seems to work , when you turn it on the cycle time comes up but it doesnt count down in minutes.
cycle timmer was at 92 mins this morning ,it has already been 2 hrs and there is still 42 mins on the timer
  • Anonymous Jan 29, 2009
    water is hot going in and the plates are hot coming out.
    just takes a very long time to run through a cycle
  • Mark Egan May 11, 2010
    Is the water coming into the dishwasher hot?
    Are the plates hot at the end of the cycle, if it ever ends?
  • 22 Answers
SOURCE: The timer on my dishwasher is really off. No
the best thing to do is replace it ... but make sure all the connectors are in place
Posted on Nov 14, 2009
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
SOURCE: dishwasher kenmore elite model 8530899
yes
u go by quick wash its take 28 minutes
Posted on Apr 18, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
futureloginn
  • 734 Answers
SOURCE: Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Dec 12, 2008
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
What is the length of time for the Normal Wash cycle on the Undercounter Elite model? Mine seems to run about 2 hours. That seems way too long to me.
Nah... that is about normal for a dishwasher today....if all else fails just soak everything to death... no real cleaning anymore...
heatman101
May 09, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
Dishwasher runs for 3 hours
You may be running the sani-wash or heated drying. The heat element in these things takes a long time.
Check these and turn them off - then try another wash cycle and time it to see - should be one hour or less
May 03, 2009 | Dishwashers
Water pre-heating
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Jan 26, 2008 | Kenmore 15912 Built-in Dishwasher
Kenmore 24 in. 16582 Built-in Dishwasher Logo
100 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
