Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Saniplus motor (flushing noise) keeps repeating
About every minute or so, the toilet pump (which also has connections from a stand-up shower and sink) will make a quick noise as if someone flushed the toilet but the sound isn't the full motor running sound when the toilet is flushed. The Saniplus website doesn't have a Troubleshooting guide so I'm hoping someone else had the same problem and can share their solution before I have to call in a plumber.
Thanks in advance.
  • Anonymous Mar 19, 2014
    Where can I buy a capacitor for my SANIPLUS
  • 979 Answers
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniplus in a bathroom with a sink & shower. It isn't used often. The water backs up in the shower. The toilet won't flush, only hums. Any suggestions?
If the pump is humming and backing up then there is a blockage on the drain pipe, blades or the impeller. Also the capacitor may have gone bad and it will need to be replaced. The capacitor drives the blade and impeller, if it goes bad then it would just hum and not pump out the waste.
Oct 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
It starts up before I flush!
is your saniplus connected to a shower or hand basin. if so - some water could be getting into the saniplus while you are on it and causing the unit to operate while you are "on the bowl". dripping taps / valves or a "leaky" toilet cistern are the most likely sources.
Dec 04, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,809 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
