Question about Microsoft Xbox 360 Wireless Controller
Xbox360 wontconnect to verizon internet DSL
I have called xbox they blame it on verizon need more ports my verizon setup is awestell 327 modem/router theexbox wont connect wireless or with ethernet cable internet works ok oncomputer verizon wanted to put me with some outfit at 14.95 a month to try to fix problem
  • 1 more comment
  • cwagon480 Jan 29, 2009
    it was posted sa cable internet really is phone line WESTELL327W is modem@router just wont talk to xbox tried manual@ auto.ethernet cable hooked now
    When i test my conection, i pass the network test , bu the falis internet. Now the xbox more help tabs says Your DNS server can't resolve the names of Xbox live or Xbox.com what should i do?
  • cwagon480 Jan 30, 2009
    triedall advice posted stillwont connect to DNS server cant install manuelly tried xbox on friend internet (COMCAST)it went right on.
  • 395 Answers
Goto http://192.168.1.1/ then click the config tab at the top, then the firewall, the default user name & password is admin. set the firewall to none allow all traffic and see if that helps
Posted on Jan 30, 2009
  • 11,896 Answers
N many cases, restarting your modem, router, and other equipment (also called "power-cycling") can fix the problem. This involves turning each piece of equipment off and back on in sequence. If you haven't done that already, give it a try now.
If you've tried restarting your network equipment and it hasn't helped, continue on for more possible fixes.
Solution 1: Change how your console gets its DNS settingsYour console is either set up to get its DNS settings automatically from your modem or router, or the DNS settings have been entered manually. To try this solution, you need to find out whether you're using automatic or manual DNS settings.
To check for automatic or manual DNS settings:
  1. Go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, check whether DNS Settings says Automatic or Manual.
Automatic: Switch to manualYour console may be expecting your router or modem to automatically assign DNS settings, but your router or modem might not be doing it. You can try to manually enter your DNS settings instead.
Note
This procedure might take a little patience, so set aside 30 minutes or so.
Before you begin, check the documentation from your ISP or contact them to get the manual, or static, DNS addresses for your Internet service. There should be two: a primary address and a secondary address. Each should be in the format nnn.nnn.nnn.nnn.
To manually enter your DNS settings:
  3. On the Basic Settings tab, select DNS Settings, then select Manual.
  4. Select Primary DNS Server, enter your primary DNS server address, and select Done.
  5. Select Secondary DNS Server, enter your secondary DNS server address, and select Done.
  6. Select Done to save your settings, then try to connect again.
Manual: Switch to automaticIf your DNS settings have been manually entered, there's a chance that letting your router automatically provide DNS settings will solve the problem.
To set your DNS settings to automatic:
  3. On the Basic Settings tab, select DNS Settings, then select Automatic.
  4. Try to connect to Xbox LIVE again.
Posted on Jan 29, 2009
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    Solution 2: Copy DNS settings from your PCIf solution 1
    fails, you can try copying the DNS settings from your PC to your
    console. If you can get to this Xbox web site on your PC, then your
    PC's DNS settings are properly set up and you can copy them to your
    console.
    You can find your PC settings as follows.
    For Windows Vista:
    1. Go to Control Panel, Network and Sharing Center, Manage network connections.
    2. Right-click your network connection (for example, Local Area Connection
      or Wireless Network Connection) and then click Properties.
    3. Double-click Internet Protocol Version 4 (TCP/IPv4).
    4. In the Properties window:
      • If Use the following DNS server addresses is selected, write down the two DNS server addresses. Click Cancel or close the windows.
      • If Obtain DNS server address automatically is selected, just click Cancel or close the windows. You don't need to write anything down.
    Your DNS server can't resolve Xbox LIVE server names
    DNS,
    or Domain Name System, is how computers find other computers on the
    Internet. A problem with DNS means that your Xbox 360 console doesn't
    know how to find the Xbox LIVE servers.
    Restart Your Network EquipmentIn
    Get step-by-step instructions on restarting your network equipment
    Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
    Note
    problem.
    solution 1 fails, you can try copying the DNS settings from your PC to
    your console. If you can get to this Xbox web site on your PC, then
    your PC's DNS settings are properly set up and you can copy them to
    your console.
    For Windows Vista:
    For Windows XP:
    1. Go to Control Panel, Network Connections.
    3. Double-click Internet Protocol (TCP/IP).
  • Nate Stansfield
    If you wrote down the DNS server addresses, you'll need to manually
    enter them on your console. Follow the same procedure as in Solution 1,
    above, to manually enter your PC's DNS settings. Then try to connect to
    Xbox LIVE again.
    If you didn't have to write anything down, your
    PC is getting DNS settings automatically and your console should be as
    well. If you haven't already, or just to double-check, make sure your
    DNS settings are set to automatic (see the procedure in Solution 1) and
    then try to connect to Xbox LIVE again.
  • Nate Stansfield
    Here is exactly what I personally did to mine own:
    change the IP by adding 1 to the last digit
    The IP Address is set so it is unique, no other device on my network has it.
    The Subnet Mask shouldn't change from 255.255.255.0 unless you have other settings in place.
    The Gateway is your routers IP, this can be found in Command Prompt using the ipconfig command.
    You should only have one Primary DNS Server set if it's just a router. This is your router IP address (Gateway)
    Is the Xbox set to DHCP? If so, it should automatically get a free IP
    address as well as the DNS settings. If it isn't, and you are setting
    the IP statically, check:
    1. The IP is valid and no other device on your network is using that IP
    2. The subnet mask is correct
    3. The default gateway is correct
    4. The DNS servers are correct (you've already verified this one)
    Make sure the Xbox is set with the same values shown on your PC.
    You'll get two DNS servers from your ISP, which is probably being
    passed via DHCP to your PC. If nothing else, try setting DNS to the IP
    addresses for OpenDNS (208.67.222.222, 208.67.220.220).
    Also
    try switching the network patch cables. Could be a bad cable, bad port
    on the switch or you accidentally used a crossover cable.
  • Nate Stansfield
    The reason your computer is working is because it already has the IP
    address from your ISP. The Xbox can't share the same IP and you can't
    just add one to the other IP address. A router will fix your problem.
  • Nate Stansfield
    Also, I have done it this way: You need a router. Like I said, the Surfboard modem (it's not a router)
    only supports a single connection. A switch does not get around that.
    You need a router in order to perform NAT. That will allow you to connect more than one device to the Surfboard and get online.
    President:
  • 1,214 Answers
I am going to guess that you may be having the same problem here as I did on my Wii. Try manually entering the IP of your router. I don't know what your router IP is, but it will be something like 192.168.0.1, with a subnet mask of 255.255.255.0.
I have fought this probelm time and time again with Wii's, and it may be the same issue with Xbox.
Let me know what you find out. I would love to help you solve this (and I'll learn something at the same time.).
    Sergeant:
  • 378 Answers
Choose a Connection Type
There are three ways to connect to Xbox Live; whichever you choose will be based on your personal preference, your broadband Internet service provider and your set-up at home. You can find more information on connecting with Xbox Compatible and other major ISPs here.
1. Direct connection
This is the fastest, easiest way to connect to Xbox Live. Choose a direct connection if:
If you need help hooking up to Xbox Live in any of the ways below, take a peek at our simple step-by-step interactive connectivity guide.
  • You want the easiest way to set up and play on XboxLive
  • You don't want to share your connection with your PC (or other device)
2. Router Connection
This is the best way to share your broadband Internet service with your PC. Choose a router connection if:
  • You want to share your broadband Internet connection with your PC (or other device)
  • Your cable or DSL modem supports an Ethernet connection
  • You want to be able to play on Xbox Live whether your PC is on or off
3. Internet Connection Sharing
This shared connection is best only if you have a USB or internal PCI modem. Choose Internet Connection Sharing if:
  • You want to share your Broadband Internet connection with your PC (or other device)
  • Your cable or DSL modem uses a USB (not Ethernet) connection, or it is an internal PCI modem
  • You don't mind turning on your PC before playing games on XboxLive
4. Set up your home network
See Guide to home networking to help you make a plan and purchase the right equipment for your home.
    Brigadier General:
  • 8,619 Answers
Hi!
Call Verizon back and ask for the latest patches. Also check This link for connection settings.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 29, 2009
    The settings are from microsoft and will guide step by step on how to connect your xbox with the network.
    Sergeant:
  • 250 Answers
The wireless adapter will be plugged in the back of the 360 thru a usb port.
The router will be connected at your computer station. The router will come with an installation cd, just follow that to connect you wireless router to your modem and computer.
After the router has been installed just go back to your xbox 360 and turn you system on and go to network settings on xbox 360. After that click on edit settings and go to the bottom and click on wireless.
Search for you wireless router name and click connect. If you setup the router with a wep key, The computer will give you an encryption code with a bunch of characters. Print that an take it with you because you will need to enter those numbers on your xbox 360.
  • Microsoft Master
  • 19,396 Answers
First you need to connect to the router by cable, and activate wireless on router, then connect the Xbox using wi fi.
Here are instructions from Verizon.
  • Ginko
    Ginko Jan 29, 2009
    If the Xbox does not even connects with cable, then it is either a firewall problem, you need to open certain ports to UDP protocol on the router.
    You find instructions here: How to set up internet connection to let my Xbox 360
    Your router IP is 192.168.1.1.
    Password to access the router are 'admin' , and 'password'.
    Regarding wireless connection, to connect wireless the Xbox you need an adapter like this :Wireless For Xbox 360.
    You need also to ensure that your wireless network is working on the router, and that you know the network key, then you configure the xbox.
    Test your wireles network using a laptop, if it works set the Xbox for the wireless.
    If you have no wireless, you need to connect the router to a computer using a cable, and open router control panel on browser (eg. Internet Explorer)
    To do that type router address on Explorer bar (default is 192.168.1.1)
    Then you are asked a user/password, put 'admin' , and 'password'.
    On the control panel go to wireless settings , start wireless and set security.
I have a linksys wireless-g wrt54g v8 router but do not have the installation cd. I have a desk top pc w/ a dsl modem and want to install the router so I can use a laptop in other parts of the house. Do...
Hi leftella, First of all, I would like to ask you few questions. 1.Who is your ISP(Internet service provider) like verizon, Bell, Comcast? 2.How many ports you see at the back of the Modem?like WAN, Ethernet, LAN, DSL, Data? 3.How many ports you see at the back of the Router?like Internet,Ethernet,WAN, LAN? 4.What is the make and model of the laptop with which you want to go wireless?
To setup the router you don't need any CD, just need to connect the Modem to router and router to your computer with hard wire Initially and then after setup, you can go wireless.
Sep 15, 2011 | Linksys Wireless-G WRT54G Router
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Xbox 360 connection withthe netgear WGR614v9
This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
How TO connect XBOX360 to Back of computer and be able to use both at the samethime. Have DSL internet
Why connect the XBOX to the computer? Can you connect it to another port on the DSL router or do you only have one port for internet connection? If so get a DSL router that will allow you to connect multiple network devices. The router will have to be configured like the current PC so that it can connect to teh internet. Then you can connect your XBOX to one of the router ports and teh PC to another port. Your PC ethernet internet connect will need to be changed so that it uses DHCP.
a second option:
You PC probably only has one ethernet port that you are using to connect to the DSL. You will need to get a second ethernet card for the PC to connect the XBOX. Not worth the trouble or $$$.
If you
Aug 11, 2009 | Computers & Internet
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
Jan 28, 2008 | Westell Wirespeed VersaLink...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Microsoft Xbox 360 Wireless Controller Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
