Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Dead spin cycle
W/P will not spin with a load in it. ????
  • 130 Answers
Motor coupling pull cabinet, pump, and motor, there it is.
Posted on Jan 28, 2009
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
Why no spin?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Kenmore Top Load Washer. Original issue was it
If the machine goes dead when it gets to the spin cycle it's the lid switch. If the the clothes are still wet after the spin it's the clutch. If the washer hums but does not spin it's either the coupler or the motor. Click HERE for a service manual. Give it a few minutes to download since it is a large pdf. Mike
Mar 25, 2010 | Kenmore 24032\24036 Top Load Washer
Washer stopped before spin and rinse cycle.
you nead to bay pas the door switch. orb replace
Nov 17, 2009 | Washing Machines
Fridgidaire front loader wont go thru spin cycle
This sounds like it is either part of the motor that is burnt out, or a fault on the control board that controls the fast spin speed.
The motors have a number of coils, so a fault with one will cause problems at just one speed.
The power transistors on the control board can also fail - leaving one speed dead, so either of these faults may be the reason yours is not working.
#1 - Check all motor coils
#2 - Check operation of output Power transistors.
Above tests should be performed by competent engineer only.
There is also another fault concerned with an unballanced load - If it spins a few times and bounces a lot, then it will abort the spin cycle. This is usually the fault of the dampers - which are a cheap replacement.
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
replace the lid switch and that will fix your problem
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Wont complete final spin and drain
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Dec 21, 2007 | Maytag MAV7600 Top Load Washer
Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
Dec 24, 2006 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
