Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer LSQ9659LW0 will not spin.
My washer stopped spinning. I found the plastic gear inside the gearbox was stripped. I replaced the pinion set and it worked for several loads and now it doesn't spin at all. It will fill, agitate, drain and rinse but no spin. I have checked the timing of the gears inside the transmission and everything seems to be ok. Any suggestions?
    Problem Solver:
  • 6 Answers
Check the lid switch. Most washing machines will exhibit the issues you are talking about with this condition. Magnetic switches go out all the time. Too bad, the mechanical type is much mode durable. You can check it a number of ways.. Jump the leads and see if it spins, check your owners manual for a 'test cycle' pull the switch out and visually inspect it (quite often they are clear plastic on the back side), place a magnet over the switch and check continuity on its leads.
Posted on Aug 02, 2007
    Novelist:
  • 159 Answers
If the washer will agitate and drain but will not spin you either have a bad gearcase or the nylon finger that engages the brake is bad. you need to remove the gearcase and check the brake assembly and if that is good replace the gearcase
Posted on Jul 25, 2007
  • Anonymous Jul 25, 2007
    and there is no step down transformer that I know of o TOP LOAD whirlpool that makes it spin
4 Suggested Answers
SOURCE:
jonniewalker
  • 1031 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
SOURCE: whirlpool imperial series 2 ultimate care washer
I had the same problem with this washer. It was the lid switch.
Posted on Dec 01, 2009
Have a Kenmore series 90 washer. During spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. In actuality, the agitator will still spin somewhat due to the oil moving the shaft.
If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators (about 1/16"). We had the same problem. Ours was a major gear noise but a clicking could also be a symptom.
A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Apr 09, 2010 | Kenmore 22422 Top Load Washer
Grinding gears when in spin mode When the washer went into rinse mode a loud sound from the gearbox happened. It sounds like the gears are grinding together and not syncing together. took out the clothes...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following:
WHIRLPOOL PARTS SITE
MORE DETAILED WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
It sounds as if the problem is in the transmission itself.
(It's not as bad as it sounds.)
If you're reasonably comfortable with basic tools (socket set, pliers/vice grips etc) getting to the transmission and taking it apart isn't too difficult and much less expensive than having a repair person charge $170 for a new transmission.
In any case, see the following for how to remove the transmission. YOU DON'T HAVE TO REMOVE THE TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=f4b39cb9484cdf1ec5d8d486fe9692d9
The first possibility is the Agitate Cams in the transmission. (Whirlpool part # 62580 / 81) (about $12)
These are two plastic pieces that lift the agitator shaft when the washer goes into spin mode.
If they are worn they may not lift the shaft high enough to keep it out of the way when the washer goes into spin mode. See the above on how the transmission works.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace).
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight gear oil (available at most auto parts stores).
Remove the transmission cover 8 bolts.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams. EVEN IF THEY DON'T APPEAR BROKEN THEY MAY BE WORN ENOUGH TO CAUSE THE PROBLEM.
While you have the transmission apart, I'd check the other cams and gears inside. There aren't that many.
As an aside, replacing the agitate cams, neutral drain assembly and oil on ours (we had basically the same problem) cost less than $30 vs $170.
Mar 28, 2010 | Kenmore Washing Machines
Kenmore 80 series washer is making a noise
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.
Jan 25, 2010 | Kenmore Washing Machines
KENmore top loader making very large noise when spinning out?
Jan 23, 2010 | Kenmore Washing Machines
Kenmore commercial washer making grinding noise
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82403140
While you've got the motor and transmission out, you should check the Motor couplers for wear.
I have a Kenmore 90 series Model # 110.28902790, during the spin cycle the agitator start to spin and then hangs up for a moment then tries to spin again.It keeps repeating this process while making a...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28902790
Please see the Whirlpool Service Manual for top load, direct drive washers.
Also see the Whirlpool Parts list for their commercial washers although the consumer models use the same parts.
The problem points to a worn Agitate Cam.
Whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
The cam is a two piece plastic part that lifts a gear above the main agitate assembly in the transmission so that the agitator doesn't turn during the spin cycle.
We had the same problem. The cams had worn enough that they weren't lifting the gear (less than 1/16").
They aren't expensive at all but do require pulling the transmission.
See the following for a description of how to remove the transmission.
You don't have to remove the tub!!
It may seem like a difficult job but it really isn't. It is a bet messy but it's a lot less expensive than a $170 transmission.
Nov 06, 2009 | Kenmore Washing Machines
Washing mashine tub pounds when spinning on kenmore series 70
See the component section on the base of the washer.
There are springs and friction pads designed to keep the inner tub from moving too much when agitating and especially spinning.
One or more of the springs may have come loose or the friction pads may have worn.
Following is the Whirlpool / Kenmore installation and service manual for top load direct drive washers with a troubleshooting section.
Also see the following for how to remove the cabinet in order to gain access to the springs and pads.
If the springs and pads are fine, I'd consider looking into the "agitator cam" in the transmission.
If the cam doesn't lift the agitator gear high enough during the spin cycle, (as we had) you would get a major vibration.
See the section in the Whirlpool manual on how the transmission works and the agitator cam.
We had to replace ours and the vibration stopped.
Only if you need to, look at the following.
Oct 19, 2009 | Kenmore 22422 Top Load Washer
This Kenmore Elite Top Load Washing machine has
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 26, 2009 | Kenmore Washing Machines
Kenmore series 80 won't spin
The following has some assumptions.
1. The timer goes through it's complete cycle.
2. If you lift and lower the lid, does the washer go into spin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the washer pump drains (and you hear the motor), the timer is directing power to the motor to reverse itself and spin the pump. (timer, motor and pump should be OK)
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pull the transmission.
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Carefully remove the clip from the main drive gear (metal with white gears.
Under it are a number of cams (the instructions with the kit show where each one goes.
Carefully put everything back together and hopefully your problem is solved.
Sep 19, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore washer makes a rapid clicking sound during the spin cycle. replaced the coupler but it didn't fix my problem. clicking starts at the end of the rinse cycle when the washer starts to drain...
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
It's possible that the main drive gear (plastic) is stripped or the Spin Pinion (Whirlpool made them out of plastic for a couple of years) is stripped.
Check the Spin Pinion and main spin gear.
Sep 19, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
511 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
