Question about RCA HD52W59 HDTV Projection Television
Is the HD52W59 HD ready or do you have to buy a seperate antenna?
I hooked up the receiver and it does not look HD.
  • 2 more comments
  • bj19872005 Jan 31, 2009
    I'm really not sure.I don't too much about TV's
  • Anonymous Jan 31, 2009
    is this cable or sat. that is hooked up to the tv
  • jason May 11, 2010
    are you recieving a high definition channel from a HD SAT. reciever or cable box ?
    are you using the DVI input ?
If you are hooking it to a coaxial conection there are 2. try the digital coax input.
Posted on Feb 08, 2009
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
Oct 27, 2013 | Toshiba 46H84 46" Rear Projection...
My Panasonic 47 inch rear view projector is hdtv ready, what do I need to buy to recieve pictures in HD
You should be able to receive the HD signal from your cable company. If you are still receiving your signal over the air, then you can buy an HD tuner. I found mine at Best Buy for $179 a few years ago. It will come with component outputs which is the HD signal.
I'm using my 70's vintage antenna on my house to receive the 3 local channels in HD.
Good Luck,
Jan 19, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Our new motorhome came with a sirius ready Jensen vr187 radio-how do we hook up to Sirius, and does it need an antenna, or is that part of ''sirius ready''?
Sirius Ready means that there is another piece the company makes that is for sale seperately from the reciever. you need to get the whole sirius system and it will just plug in and play through your existing setup.
Nov 18, 2009 | Jensen Car Audio & Video
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Conversion to DTV from analog
IF YOUR UNIT HAS AN ATSC TUNER THEN IT IS HD READY. SEE YOUR OWNERS MANUEL. HOOK THE ANTENNA TO THE RF (ANTENNA) CONNECTOR .GO INTO THE MENU AND AUTO PROGRAM CHANNELS. GO TO CHANNEL 5 AND SEE IF YOU HAVE 5.1 OR 5.2 IF SO YOUR DONE.
Jan 30, 2009 | Akai LCT2721AD 27 in. LCD Television
HD ready?
If it is HD ready it will have HD component cable hookups. They are the red, blue, and green color coded hook up. You may also have RGB hookups which will look like a usb port. If you have any of these hook ups located on the TV then it is HD ready. If not then you were told false information. Let me know if you have any other questions.
Jan 24, 2009 | Toshiba 50A50 50" Rear Projection...
Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Dec 27, 2008 | Hitachi 51F510 51" Rear Projection...
No signal on dtv do I need a DTV antenna
You have an awesome antenna - every one should have one like it!
An antenna that used to work with the older analog signals will work with the digital ones. What you have to remember is that analog systems though subject to ghosting, were brutes signal wise ala the metal on older cars. Digital signals are frail and even tree leaves in between the antenna and transmitter can have adverse effect on signal received.
If the sound is weak on your set that is a function of your sets audio section. Somewhere you are losing gain and/or amplification. If you have an audio output you might consider hooking that up to one of the audio inputs on audio receiver. It will work fine and that is what I did with my unit.
Sep 05, 2017 | RCA HD52W59 HDTV Projection Television
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
