Question about Zebra LP 2844 Thermal Printer
Zebra TLP 2844
Hi master,
just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help.
The problem is that printer after print request roll out plenty of labels (empty), consequently onle label full of marks and this is still repeating. I have tried to print windows test page but result still same...
Thx Patrik
Patrik.Matouch@wscnet.cz
  • Stephen Clouthier
    Stephen Clouthier May 11, 2010
    No a master but hopefully can help. i do believe that it is not a printer issue but you will find out after the reset. I think it is a windows command that is telling the printer to send out extra blank labels after each print. Somehwere there is an AUTO advance command that is switched on. But see the attachment below. these are the button commands for the TLP-2844.
Call BarcodeWarehouse.biz 1-888-422-9249 - they offer free tech support on Zebra printers even if you didnt buy it from them. They helped me fix mine in about 3 minutes when I had given up was calling to buy a new printer!
Posted on Feb 12, 2009
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It...
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Mar 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 problem "AUTOFR"
Comment est que voue envoyer des commandes?
Est que vous utiliser USB?
COPY file USB??? quelle est la syntax? pas de LPT1 sur ma machine...
donque COPY file LPT1 /A ne marche pas
Just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help. The problem is that printer after print request...
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 Thermal Printer Logo
564 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
