Question about Kenmore 30 in.32099 / 32094 / 32092 Gas Cooktop
Kenmore 32099 Cooktop burners regulation
Hi I just bought this cooktop, but the flame come up to high and strong, I wish I could diminish the flame but I don't know how can somebody help me out? Thnx
  • 3 Answers
When the cooktop was new it was built for NATURAL gas. Make sure FIRST that it has been converted to L/P (PROPANE GAS). Then on some models you can adjust flame height by removing the knobs from the stem and taking a very small blade screwdriver and while holding the stem in the LOWEST setting adjust accordingly to your desired height.
Posted on Sep 12, 2008
  • 3 Answers
Remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Posted on Jul 25, 2007
SOURCE:
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
The high flame doesn't seem to be working on any burners
hi gud day...try to remove the nozzle inside the burner base using open wrench(depend the size)the use vacium,put the vacium were the place of the nozzle,i think there some dirt inside..then return it again the nozzle to check if it works,,if not replace the regulator for the 2nd sollution.
tnx gerbee
Sep 11, 2009 | GE Profile JGP636 Gas Cooktop
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Aug 09, 2008 | GE Cooktops
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Gas cooktop
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
Aug 27, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Kenmore 30 in.32099 / 32094 / 32092 Gas Cooktop Logo
248 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
Kolbrun...
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
