Question about Amprobe Digital Megohmmeter, Model# AMB-45
Will the Amprobe AMB-45 test coax cable output?
I have a new modulator that i recieved that does not seem to work, can I us the Ambrobe tester to test the out put on the modulator? and if so, what is the correct set up to do this?
Thank you,
Bob Shilling
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
The Amprobe Digital Megohmmeter, Model# AMB-45 is an insulation tester that checks to see if conductors are leaking current to ground or the shield in a coax, for example. It will not check the output of a modulator, it may actually damage the modulator.
Posted on Mar 01, 2009
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
I am looking for a user manual for an Amprobe AMB-4D Megohmeter. Any chance you have one? Thank You for your assistance MJ Messerly
This is the only manual I can find:
http://www.testequipmentdepot.com/amprobe/pdf/amb4d_manu.pdf
It is pretty vague but should have the information you need to get started. The sale of this unit has been discontinued.
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Garden
Megger testing of wire insulation. what represents a good reading and what is a bad reading. Using a AMB45 (Amprobe) Is an "OL" good or bad?
Hi
OL is a good reading, it represents a reading of greater than 400Mohm, with any insulation testing the greater the value the better.
Thanks
Danny
Apr 12, 2009 | Amprobe Digital Megohmmeter, Model# AMB-45
Refrigerator
There should be a drain hose that takes the melted ice (water) out the back and down into a pan under the refrigerator where it evaporates. Check inside the lower part of the freezer for a small hole-it needs to be clear to let the water run through the tube and down into the pan. The tube can usually be disconnected behind the unit to clear it out with a wire or hanger. Good luck
Oct 16, 2008 | Amprobe Digital Megohmmeter, Model# AMB-45
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Oct 23, 2007 | Car Audio & Video
Amprobe Digital Megohmmeter, Model# AMB-45 Logo
110 people viewed this question
Top Amprobe Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Amprobe Hardware and Accessory Expert? Answer questions, earn points and help others
