After the dishwasher drains - I can hear it click and begin the drain cycle; I've opened the door after the drain cycle to see there's no water, however, a moment or two later, water comes out from the water blades.
Clean the drain filters: click on filters
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
SOURCE: My dishwasher does not drain completely. There is
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
SOURCE: Dishwasher won't drain when cycle
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Daniel
Hi
Daniel
