Question about ASUS Eee 4G Notebook
I have tried and tried and i cannot get my asus notebook to connect to sky internet, either with wireless or using the ethernet cable.
Bought an Asus K55VJ-SX218H notebook for college & can't connect to their wireless Internet. We've also tried connecting using cable with no luck. It connects to my home wireless but not t
You need to contact the college's IT support to get the college's wireless router configuration settings so you can configure your laptop's wireless with these settings.
Mar 04, 2013 | ASUS Computers & Internet
ASUS Eee PC 900 Notebook will not connect to the internet
What does it say in software? Wired or wireless? Try a Ethernet cable. NWin XP?
Jan 02, 2013 | ASUS Eee PC 900 Notebook
I got a ASUS notebook pc...how do I connect to the internet? I am TIME WARNER cable...
What OS are you on?
Here is a guide for XP:
http://www.egr.msu.edu/decs/how-to/connect_to_wireless_network_using_windows_xp
Dec 11, 2012 | Computers & Internet
I got a asus g53jw-a1 and when i connect my internet cable to it.it goes very slow and when i connect it to another laptop that isnt asus its goes normal and fast. i have 2 computers and the internet goes...
Do you have your wireless connection enabled as well as your LAN connection (wired) connected and enabled at the same time? It may be as simple as turning the your wireless card off when your are connected with a wired connection. I would try that first and see if it that could be the issue. Shut the wireless card off and see if your results are different with just the ethernet cable connected.
Cheers!
J the Guru
Oct 16, 2017 | ASUS G53Jw-A1 PC Notebook
How do i install my asus wireless adapter to work on my xbox 360
You need to set it up on a computer first.
And of course you have to already have a Wireless Router connected to your DSL/Cable modem.
I did my setup on a Mac so there are quite a few more steps to go through on a Window's machine then I had to do but just use the manual as it's set up for a Window's anyway.
You might just try skipping all the installs first and just try connecting to the ASUS with the IP number first via a web browser and see what happens.
When you finally make it into the ASUS, pick "Ethernet Adapter" mode.
Basically just set it up as if you were using the ASUS to connect to the internet on the computer.
When you can use the internet normally on the computer via the ASUS then just unplug the ethernet cord from the computer and just plug it into the X-Box. Then all you do is go into the network settings on the X-Box to set it up as a LAN/cable or "what ever" connection NOT wireless. The X-Box should see it as a LAN because you are using the Ethernet port.
I haven't done it on the X-Box but I did set it up that way on my BlueRay disk player and it works fine.
Nice thing about this ASUS is you can use the USB port on the X-Box to power the router INSTEAD of the power cord so every time you turn the X-Box off the router should turn off. (if you don't have an external cooling fan on the X-Box using it) Another good thing is you can actually use a longer Ethernet cable to get the ASUS closer to the main router (near a power outlet of course).
Dec 26, 2010 | ASUS WL-330GE 802.11b/g Wireless Access...
My asus eee won't connect to the internet via wireless
Contact Asus technical support for getting your wifi problem fixed
Get the best Asus Computer Support by Asus Support
http://asus.techssupport247.com/
Jan 24, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Wireless cards is it built in
If you are referring to the notebook having wireless connectivity (being able to connect to the internet via your wireless modem) then YES!
It comes with the Intel High Definition audio modem and 10/100 Base T PCI LAN on board, which will allow you to connect to the internet. You can also use the RJ45 plug to connect to your modem with an ethernet cable.
Nov 19, 2009 | ASUS A3H Notebook
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
ASUS Eee 4G Notebook Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
