Question about Dryers
Noisy Zanussi TD260 Tumble Dryer
With the side panel off the noise seemed to be coming from the motor bearing but having removed the motor it feels OK (no load of course). What is the most likely cause?
  • 4 Answers
If the motor is ok the next thing I would check is the felt strip which is on the rear of the drum and is usually glued down. When this gets worn the noise can be really intolerable. You can buy new felt but the drum has to be removed in order to replace it. Not a fun job!
Posted on Jan 28, 2009
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
How do I replace the front felt bearing on a zanussi tumble dryer?
The top and back panels have to come off. The belt taken off and the bowl removed from the machine. Lie the machine on its front. You can then see where the felts go. Some of them are held in with steel spring clips, early models are glued in onto the lip that supports the drum.
Jan 03, 2015 | Zanussi TD4112W Electric Dryer
How to repair a zanussi condenser tumble dryer belt
Access from the rear panel to drive belt:
- Remove the worktop
- Remove the side panels
- Remove the rear panel cover
- Remove the motor unit
Dado
Oct 03, 2014 | Zanussi TC7102W Electric Dryer
Zanussi tc470
DEFO BEARINGS WHEN YOU SEE THAT DUST A REAL SIGN
Jan 22, 2014 | Dryers
Noisy in one direction
undo the plate at the back,,, the fan on the motor needs to be replaced,, that is the plastic fan.. sometimes you need to replace the one on the inside aswell,, try the back one first.. its not the motor,.. it is the plastic fans
after a period of time they just wear
Oct 18, 2012 | Zanussi Washing Machines
Tumble dryer works ok but its really really noisy.
Sounds like you have a bad drum bearing. It's seems loud because the clothes drum aplifies the noise. Depending how old it is will determine if repairing is worth the cost. Once you have decided that, replace the drum belt and check all bearings including motor. Clean out all lint which can become a fire hazard.
Oct 15, 2009 | Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
GE Dryer DPSR483GA2WW too noisy
Remove the rear panel from the unit. This should expose the motor, drive belts, and the drum bearings. Now turn on the unit and your may be able to determine where the noise is coming from. Keep your hands away from moving parts and electrical connections!!
Ray
Dec 14, 2008 | LG DLE3777 Electric Dryer
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
