Question about Denon AVR-1908
Intermittent low hum in TV/cbl mode works fine in tunner DVD mod
Using component video connections
  • 2 more comments
  • docc546 Jan 29, 2009
    Thank you for your replies. I switched out the audio cable connection for a coaxial connection. That solved the problem. I wanted to use an optical audio connection but I was unable to make much sense of the user guide instructions. None of the optical ports on the back of the unit were labeled tv/cable so I decided to leave well enough alone. Again, thank you for your help.
    Doc
  • nogenius835 May 11, 2010
    Usualy optical signal will output whatever is set to play(audio) and in the amplifier there sould be a ``optical in`` that can be selected(like a video 1 port)
    you should theck if the connetor inside the machine have not been
    broken on the solder side,check by moving the connecters sligthly
    while listening to it(that problem is easy to fix)
  • Scott Frye
    Scott Frye May 11, 2010
    Hi..
    Can you replace the cable youre using on the TV/CBL connection?
I switched out of the audio-out cables from the cable box to the audio in at the Denon receiver and went with a coaxial cable connection. That switch got rid of the hum. I don't understand why the initial connection produced the hum, but the unit is working fine now.
Posted on Jan 29, 2009
I have a scott tv...2 days ago an electrical storm hit the cable lines....i had to replace my modem, router and call cable company to repair lines...tv works fine on all other connections, ie; laptop, dvd,...
TUNNER BAD, YOU NEED TO CHANGE THE MAIN BOARD OR CHANGE THE TUNNER WITH AN OLD USED BOARD. MAYBE IF YOU OPEN THE TUNNER FIND A OPEN LINE NEAR COAXIAL CONNECTOR.
Apr 20, 2010 | Scott LCT37SHA TV
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
S video displays, but Component video is intermittant
Shall we assume that the DVD is fine, before addressing the TV issues? Does it work with any other device or component? Seems that if your S Video is clean, then it's just a matter of refining whether your DVD is as well. Check that, and let us know.
Feb 12, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Intermittent sound with cbl/sat. Sometimes sound
Your receiver is HDMI version 1.1,1.2 or 1.2a and just don't work with anything to be honest with you. It's an HDCP (copyright Issue) and 5v pass thru issue. and the list goes on. If you can, just run HDMI directly to the TV and optical or Digital Coaxial to your receiver for audio and all will be well again. If you need more help, just post a comment and I will gladly help some more
Jun 24, 2009 | Onkyo TX-SR875 Receiver
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Apr 09, 2008 | Yamaha HTR-5930 Receiver
Picture is of poor quality (wavy)
This may indicate a problem with the RF tuner. When you are using the DVD player is the output of the DVD using the F (RF Coax) Conncetor or is the DVD connect to the TV using the Video/Audio cables (either Composite (Red, White, Yellow) or Component (Red, Green, Blue)). I am do however believe this to be a RF tuner problem. Make sure that the TV is set to channel 3 and the cable box is connected to the TV (set to channel 3). What you could also do is get digital cable and use the video output jack as the input to the TV on one of your aux positions.
I would first make sure the tunner is on channel 3 when using the regular cable box, or if you are using the TV's cable ready features make sure the tunner is working correctly, this might have to be done by a qualifide TV repair person.
I hope this helps
Thank you,
Shuttle83
Nov 15, 2007 | Toshiba 57HX81 57" Rear Projection...
Denon AVR-1908 Logo
122 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
