Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Sony memory card
How to insert sony ms into monitor
Push in, don't pull out....kinda like...... at the end of *** with a girl!
Posted on Sep 19, 2009
I uploaded pictures from my sony dsc-s650 last night onto my computer and i didnt know that it was going to completely erase them from my memory card. is it possible to get them back on there?
Hi,Unless you FORMATTED the memory card when it is in the camera thru your camera
MENU pictures should be there..
To find out that either connect the camera to computer or take the card out and insert the card reader slot of your laptop (if not you may need Memory Card Reader " THAT COMPATIBLE WITH YOUR MEMORY CARD.This card reader facilities TO DOWNLOAD YOUR PHOTOS/VIDEOS to PC too....As an example of this unit pls visit the URL below....you can buy it any electronic Market too..) and to see if the pictures are still there..if you have erased them and you still want to recover them you need to download a RECOVERY program to ypur PC.,If you need more help ,Let me know the result...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
26-IN-1 USB 2.0 MEMORY CARD READER FOR CF/xD/SD/MS/SDHC
http://cgi.ebay.com/26-IN-1-USB-2-0-MEMORY-CARD-READER-CF-xD-SD-MS-SDHC-/290583009260?pt=PCC_Drives_Storage_Internal&hash=item43a818d7ec
Jul 13, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
I bought a 2gb memory stick for my psp, once i insterted it in an orage light keeps blinking and while i put it on usb mode it says there is no memory stick insterted when there is
If the MS light keeps blinking continuously, that means that the PSP cannot read the MS you inserted. That happens normally. You just need to take it out, then put it back in. That's the simple fix there.
To pull it out, open the MS slot first. Gently push the exposed part of the MS, inward to pop it out.
When putting it back in, make sure that it's perfectly aligned and that the light blinks fast only for a couple of seconds (2 to 4sec) and then immediately stops. That means, the MS is properly placed and can now be read.
May 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
When I try to insert a memory stick into my sony cyber-shot dsc-p20 it won't lock in place and I can't close the door. Help!
Try quickly pushing the card in and letting it go, fast. Keep trying this and see if the card finally locks, you could have a build up of fluff on the latching mechanism. doing this could free the fluff and problem solved.
Its also possible that the latching mechanism has dislodged which means a dismantle at a repair shop.
Apr 10, 2010 | Sony Cyber-Shot DSC-P20 Digital Camera
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
My s500i wont read the memory card, hoe do i fix
Try to format your MS from another phone (or a cardreader).
Otherwise do this:
1. Insert MS into your phone
2. Do a master reset: Menu->Settings->Master reset->Reset all
BACKUP YOUR FILES BEFORE THAT! Master reset will delete all your files, contacts, etc.
Oct 03, 2009 | Sony Ericsson S500i Cellular Phone
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
How to insert memory card?
see manual which can be downloaded from www.brother.com
It might be that the Sony MS belongs within another cart slot.
Jan 18, 2008 | Brother DCP-110C All-In-One InkJet Printer
My memory card is inserted, but its telling me its not!
first is try checking its memory terminals maybe their something blocking it or you inserted it in a wrong position.
or try restoring your phone to its factory settings...
 if still nothing happens maybe you have a defective memory card. or to be sure try using other memory card, if still cannot read it theirs a prob in your memory slot internally....
hope you solve it...
Jun 23, 2007 | Sony Ericsson W300 Cellular Phone
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
35 people viewed this question
Alun Cox
