Question about Toshiba 57H81 57" Rear Projection Television
Convergence poblem how can I fix the convergence problem?
  • richard long Jul 25, 2007
    What are the IC'S? and where can I get them?
    President:
  • 3,130 Answers
You will need to replace the two convergence IC's. But if you do not have any solid state repair experience, play it safe and get a tech to assist you in this repair. Good Luck
Posted on Jul 25, 2007
  • Larry  Dillon
    Larry Dillon Jul 25, 2007
    You can look on the printed circuit board for two black squares that start with STK. You can order them from MCM electronics. Then you have to get some heatsink compound and before you install the new IC's onto the printed circuit board, you rub the heat sink compound on the backs of the new IC's. Be very carefull when you are soldering or unsoldering, as it is very easy to ruin the printed circuit board with too much heat. If you have little or no soldering experience, have someone you know who does have soldering experience to do the soldering and unsoldering for you.
SOURCE:
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
Philips 50P8341 50 in. Rear Projection Television
normally when something like this happens, we could right away propose what can be done, in your case, since youve already changed a lot of parts on that tv, you can at anytime fix it. the tv alone is not fixed yet as of the moment but to some it up, experts have already given you some ideas on how to fix the tv. cheers. hope youll fix that tv in no time.
Mar 12, 2008 | Philips 50P8341 50" Rear Projection...
No Convergence adjustment option in my RCA Projection TV
please check out the fl231 fuse poblem in the tips and trics under willtab profile you may have this simple repair
Jun 17, 2009 | RCA D52W23 52" HDTV CRT TV
Inteldg31pr comming poblem to install
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alkllklju14
Apr 14, 2009 | Intel DG31PR Motherboard
Fl231 replacement
ok first lets determine if the fuse is the poblem. do you have convergence option in the setup in customer menu. if you do then it will not be the fuse. if you have that option go into blue and red convergence. when you arrow over left or right up and down do the cross hairs move if they dont then it will be the power board(convergence)
Sep 24, 2008 | RCA HD52W59 HDTV Projection Television
Poblems with colors lining up
Look in the menus for the convergance adjustments. It sounds like red is out of adjustment.
Jun 12, 2008 | Sony KP-57WV600 57" Rear Projection...
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshba satellte a135 s2276 poblem
It Fell?
It's possible that the keyboard cable needs to be reseated. This isn't too difficult. LEt me know if you want instructions
Good luck
Oct 31, 2007 | Toshiba Satellite A135-S2276 Notebook
I have a huge poblem
This will do the trick http://www.mympio.com/index.php?topic=13.0
May 09, 2007 | Mpio FG200 MP3 Player
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
