Question about Ricoh Aficio 1085 Laser Printer
Reset Duplex Unit Correctly on Ricoh 2232C
We have a Ricoh model 2232C. We are trying to print duplex copies but it is saying "Reset Duplex Unit Correctly" and will not print. How do i reset the Duplex Unit Correctly?
It happened to me on a 3228C and after 2 days diasembling the duplx unit on the left side of the machine, I found out that the problem was on a black tray inside the main unit, under the fusers, it was pulled out just about a quarter inch. All that needed to be done was to push it back in and serure it with screws.
Posted on Feb 29, 2012
  • probeturbo94
    probeturbo94 Feb 29, 2012
    In spanish it said " vuelva a colocar la unidad duplex correctamente "
  • probeturbo94
    El problema en mi 3228C era que no imprimia duplex y el problema estaba en una bandeja en el interior de la maquina principal, la bandeja negra debajo de los difusores, es una bandeja que esta en el interior de la maquina, se habia salido medio cm, con lo que lo unico que tuve que hacer fue empujarla ese medio cm y poner unos tornillos para que no se vuelva a salir.
    Problem Solver:
  • 11 Answers
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Posted on Jan 31, 2009
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
How to install Duplex mode on PC for Ricoh aficio 2027
If you go into the print driver settings (Control Panel > Printers & Faxes > right click on the Ricoh 2027 and select Properties) there is a list of the available accessories under one of the tabs (I think it's either Accessories, Advanced, or something similar). Depending on the specific driver you have, you can either check the option for the duplex unit and then click Apply, or you can click the Update Now button to have the software itself check to see which options are installed on the copier.
Either way, you should be able to print duplex copies once you've done of those two things (assuming you actually have a duplex unit installed on the copier, of course).
Jul 09, 2010 | Ricoh Aficio 1085 Laser Printer
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
Cant find the setting for double-sided printing on a Ricoh printer
Go to the start menu from the windows desktop then go to printers and faxes then when you will see the driver for the AP 3200 click the right click while the pointer is on the driver and then click properties from the drop menu, then go to accessories and see do the Duplex unit is selected but first see do you have the duplex unit on your printer you will easy notice by the picture when you will select the duplex unit.If you have the duplex unit on the printer then just select the duplex unit then click apply and then ok and now you can close the window. now when you will want to print duplex when you will click the print button from the word or PDF document go to properties and select that you want to print duplex
Jan 26, 2010 | Ricoh Aficio AP3200 Laser Printer
Ever since we changed our fuser oil on our ricoh 2238c the paper is getting jammed and we have stopped that by rerouting the printer to the external tray but we can no longer print duplex any solutions and...
If it's only happened since you replaced the fuser oil, maybe something isn't sitting in there correctly. Try removing the oil supply unit and fusing unit and then reinstalling them.
Sep 24, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh AP410 Duplex Error
it is possible that the duplex door switch or actuator is bent or out of position and not making good contact the switch on that model is a small plastic switch and it may need to be replaced if that is the case you may need to call a ricoh service tech to replace the switch.
the switch is inexpensive a few dollars but the cost of the csr could be $113.00 per hr or more.
good luck!
Jul 07, 2009 | Ricoh Aficio AP410N Laser Printer
Double sided issues
Duplex means 2 sided copying. If you have an odd number of pages, then it will do this if you are sticking them all together (if I understand what you are saying correctly). Either seperate your jobs or stick a blank piece of paper at the end to correct this. Again, I am not sure if I am understanding your situation correctly, but I think that will correct it if its what I think you are saying? Clear as mud, huh?
May 22, 2009 | Ricoh 3310LE Copier
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Ricoh Aficio 2035G Duplex issue
When you open the whole duplex unit you will see a very small metal tab with a screw, on the top right side on the machine. This activates the switch on the duplex unit.
Or with the duplex unit open you will se a small rectangle hole inside a switch, put a piece of paper or something to activate it, might got stuck.
This problem is very common on this machines.
Nov 18, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1085 Laser Printer Logo
1,432 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
