Question about SanDisk 2GB microSD Memory Card
Transflash adapter wont work
I got a sd memory card reader with a free sandisk transflash adapter. I had no idea what the adapter was. After reading about it, it seems to be storage. I tried it in my camera but it says "card error, card is locked". After going to sandisk web page, they showed how to unlock (little lock on left side move to top) I did this, but still it wont work. When I put it into my card reader and plug into PC via USB, it recognised the Card reader but doesnt see the adapter. Is this adapter for storage? does it work in a camera like a normal sd card? How do I unlock it because ive moved the lock to the top, but wont unlock.
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
I Have absolutley no idea where to plug this product in at on my laptop.
If your laptop is less than 5 years old, you should have a SD card slot on the side of it, which is about the width of a postal stamp. You need to plug your microSDHC card into a "SDHC to SD card adapter" first, then you plug the whole thing into the SD card slot. Otherwise, you need to buy a card reader that takes a SDHC/Transflash card directly, then you plug its USB plug into one of the USB sockets on the side of your laptop.
May 22, 2011 | SanDisk 4GB microSDHC Memory Card
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Not knowing how to insert into hard drive.
You need a USB to Flash card adapter, you push the little card into the slot, and if it is a mini card, it has to go into another card "Carrier" that plugs into another adapter, that then plugs into the PC, either through the USB adapter or a slot in PC, anyway, when you insert it, automatically, a driver will be installed, it is "Built into" Windows, now after it has done so. you can simply use it as a "Drive", meaning you can Copy, Cut, Paste.
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
I have a SanDisk 4GB MicroSD (TransFlash) Memory Card, bought to use with a Nokia 3109 mobile pone. The phone indicates that the disk is unformatted [and doesn't format it]. My laptop [Windows XP...
Sounds like a defective card. Some phones only take up to 2 gigs, and will not format anything larger. Try the card on another phone or computer.
Jul 25, 2009 | Electronics - Others
Cant fit my transflash adapter to my pc
ceejay_thomas,
Does your PC have a SD slot for the transflash adapter? If not you'll still need a SD to USB adapter to plug the SD into. If you have a Sony it may not be an SD slot it may be a Memory Stick or Memory StickPro which is not the same.
randy320sgi
Jan 16, 2009 | SanDisk 2GB microSD Memory Card
Axim x5 sd not reading
I would think it is having more trouble with the adapter than the actual card. It could also be the storage size of the card that is the problem as well. Try a regular 2GB SD Card and see if it works. If it does, then it is probably just the adapter.
Jan 01, 2009 | Dell Axim X5 Pocket PC
My micro sd card doesnt work in my transflash adapter.
Try to clean the card's contacts with a clean cloth or a tissue paper and reinsert the card in the adapter. Maybe the adapter is defective.
Nov 20, 2008 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
Where do i insert my sandisk microsd/transflash adapter?
This adapter will be usuall USB . Kindly verify you have the right adapter for memory. Else you will be having housing for the MICRO SD. AFTER THAT YOU MAY USE IT ON USB CARD READER
Apr 12, 2008 | Computers & Internet
SanDisk 2GB microSD Memory Card Logo
230 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
