Question about kawasaki Full Suspension Mountain Bike Men
2004 Kawasaki Prairie 700 wont start
The machine gets lots of fuel, spark, and the battery is good but wont start cold, yet a couple of tugs on the cord , and away ya go, then it wont idle until its warm even with the idle turned all the way up. I put new coils on it, new igniter box and new plugs. Timing maybe?
Never mind guys, i figured it out, the valves actually tightened up and pushed them off their seat, no compression, so i got the feeler guages and fixed it, lots more power now:P thanks anyway.
Posted on Jan 31, 2009
I have a 2004 Kawasaki KFX 700 has no spark I changed the ignition switch, coils, CDI and rectifier and still nothing.
Hi, Adrian and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below Good luck and have a nice day.
kfx 700 no spark
KFX wont start no spark Kawie Central Forums
Nyroc ATV info website
http://vitek.vellum.cz/manualy/Kawasaki%20KFX700%20V-Force%202003%20Service%20Manual.pdf
May 07, 2016 | kawasaki Motorcycles
1999 Kawasaki 300 Prairie. Where can I get a diagram showing fuel line routing?
Hi, Gary sorry you can't find the first and best tool you ever bought for your Kawasaki despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1999 Kawasaki 300 Prairie fuel line routing Google Search
ATV Connection
Where do connect the fuel line that goes from the carburetor to the engine
https://www.tradebit.com/filedetail.php/276766770-kawasaki-prairie-300-service-manual-repair-1999-2002
Apr 02, 2016 | kawasaki Motorcycles
I have a 1997 Kawasaki Prairie 400 4 by 4. It has sat for a while and I would go start it and stuff but after it sat for awhile I rode it and it rode fine. Now It bogs when I push the throttle. Help
Hi, Bridger if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Kawasaki Prarie KVF400 ATV Repair Project Part 1
https://www.tradebit.com/filesharing.php/search/0/1997+kawasaki+prairie+kvf+400+f
Owner Manuals Service Manuals Kawasaki Vehicles
Dec 28, 2015 | kawasaki Motorcycles
Will idle & run at slow speeds, bogs down at higher speed.
Prairie 360 revs high but goes slow (45mph) - Kawasaki ATV Forum
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Oct 27, 2008 - 2006 Prairie 360, wife's ride, polar white, with 26" Swamp Lites on SS108's. ... that it has a low top-speed...45mph is about as fast as they seem to go. ....air cooled motor theres no real performance there, the P360 wts are light ... Can't put 2005 Kawasaki KVF 360 into gear
Jun 30, 2013
Prairie 360 speed/power issue?
Aug 28, 2012
06 Prairie 360, too many rpms???
Nov 30, 2011
2004 Prairie 360: WOT miss
Nov 9, 2011
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki 2005 Prairie 360
Turn key no power
you have to have it in neutral ..
Apr 25, 2015 | kawasaki 2004 Prairie 700 4x4
How do I reset limp mode on a 2004,700 prairie?
Make sure your drive clutch spring isnt broke.
Sep 17, 2014 | kawasaki 2004 Prairie 700 4x4
Wont start cold
Check the fuel pressure when you first come out in the morning.
Apr 01, 2014 | 1995 Jeep Wrangler
Speed problem
check the alternator. if the engine is running fine no problems but stuck only doing slow speeds would check the charging. if this is fine check the spark coil.
Mar 11, 2014 | 2004-2006 Kawasaki Kvf700a B Prairie 4x4...
I have a 04 prairie 700 that loads up and back fires through the carbs at mid to full throdle. Starts and idles great. just replaced plugs and fuel after being stored for 3 months. I cleaned the jets and...
what did you use to clean the jets? if you stuck something inside them, you could have reamed it out a little to a larger size. you can try leaning out your mixture screw a little and see if that works. if not, you might have to replace your main jets.
May 20, 2010 | 2004 kawasaki ZR-7
kawasaki Full Suspension Mountain Bike Men Logo
826 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
