Question about Pioneer SD-533HD5 53" Rear Projection HDTV
What does ics mean?
What is a ICS
  • 4,234 Answers
ICs are Integrated Circuits. These are the black multipinned parts you see everywhere these days.
Dan
Posted on Feb 07, 2009
No problem just need to know the year of my tv. GE 19GT356
not familiar with your model,but any ics inside will have a date code at the bottom(not all ics) eg.9746
means 1997,batch 46
hope this helps a bit
regards
steve
Apr 07, 2011 | GE Televison & Video
The tv just turned off on its own this morning and will not power back on...the power button is blinking 3 times when we push the power button..either manually on the front of the tv or thru the remote...
3 Blinks means Convergence -replace Both STK ICs they are big black ICs and will have Part number on them STK392-110 Mats Electronics sales ICs 1-800-628-1118
Feb 15, 2011 | Panasonic PT-51HX42 51" Rear Projection...
Can someone help Panasonic tv will not turn on power light 3 blinks and a pause (pt-53wx42-53
Hi
Thanks for using FixYa. 3 blinks issue means failed convergence (STK) ICs which needs to be replaced. To do this yourself you should require some basic knowledge about soldering-re-soldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I see a blur to the picture and words are double looks like 3D
Thats a common problem with rear projection TVs which means the convergence ICs have failed. Replace both ICs and that should takke care of the problem, be sure to check the feed resistors also.
May 09, 2009 | Televison & Video
Toshiba rear projection 57H81 Model
most possible cause is failed convergence ICs. Unplug the three wires for the convergence yokes then try powering up the set if it powers up the Convergence Ics need replacement
Mar 04, 2009 | Toshiba 57H81 57" Rear Projection...
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
CONVERCENCE PROBLEMS
did you replace the convergence resistors with the ICs? Often the resistors will need to be replaced also when new ICs are installed. 3 blinks means convergence Failure so its either the solder connections on the ICs or the resistors need replacement. If you need more assistance please let me know.
Sep 27, 2008 | Televison & Video
Panasonic PT-47WX53
Your convergence ICs have failed thats what 3 blinks means. You will need both convergence ICs number STK392-110 you can get replacement ICs at this link and they provide free instalation instructions with pictures plus free on line tech support when you do the repair. here is the link.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Mines blinking 3 times and then pausing
3 blinks means convergence. The Ics cost about 10.00 each you will need to replace both of them. Also check the resistors that power the ics. They are located right next to the ics easy to spot theres about 7 of them all identical with no color bands on them like normal resistors have.
Mar 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
66 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
