Question about Panasonic Panafax UF-560 Plain Paper Laser Fax
How to set time and date
In the instructions it tells me to go to function 9, then number 2 as set time and date, from here i get told to put in file number___. what file number? there are no files in there. anything i try just returns it to the start. it has the date 1st january 2000. please help DJ
    New Friend:
  • 16 Answers
Function 7 then 1 push set 4 times diplay says ID push clear a few times(depends on how long number is)to remove then input new number and push set,then stop to get out of that.(This also where you set time date and company name) THIS IS FOR ALL PANASONIC FAX MACHINES.
Posted on Jul 26, 2007
SOURCE:
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Forgot how to fix the time
Press shift right (orange button), then press 9 (time function). Now choose 3 (set time, date...), put the hour number, press ok (F) ; do the same thing for minutes and seconds. After all press ok again.
Oct 05, 2009 | Canon P170-DH Calculator
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Time/date
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Visys time/date display settings will not stay correct - help please!
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Jul 07, 2008 | RCA 25404RE3 Corded Phone
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Router stops responding with red alert light turned on
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
http://booobi.googlepages.com/uperJerry_V2.8b4_Worldwide_A.rar
Oct 20, 2007 | 3Com OfficeConnect Wireless Router
Time/Date function for C-770
I dont know if this is any help because I am not sure if you actually want the date and time stamped over the top of the picture or if you just want it to have a record of the date and time with the picture. If the second option is OK then when ever you take a picture with all digital cameras I have owned and the c-770 is my newest it puts a tag in the file so that when you right click on the picture and go into the properties you can select the summary tab at the top and click on the advanced button and it will tell you every setting that the camera was set on to take that picture including the date and time it was taken.
Sep 12, 2005 | Olympus Camedia C-770 Digital Camera
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
342 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
