Question about Samsung LN46A530 46 in. LCD HDTV
Number 2 in upper right hand corner of screen
I have a new Samsung 46 inch HDTV. there is a number 2 in the upper right hand corner of the screen that I can't get rid of. Please advise i just purchased a new Samsung 1080p 46" TV and have the same problem. There is a number 2 displaying in the upper right quadrant
inside a grayed out box that I can't find a way to clear. Anyone solved this?
  • 1 more comment
  • bshire Jan 30, 2009
    I have the same problem on my LG LCD TV.
  • LindsAy2168 Mar 17, 2009
    I had this same problem! I officially do not like the number 2! Just follow "datajayden's" instructions! Unplug everything and wait 60 seconds! Worked like a charm!! Thank you!!
  • Anonymous Mar 17, 2014
    I have debug on my screen. Samsung 46 inch, can anyone help?
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Posted on Feb 01, 2009
Cracked 46 inch screen on my Samsung tv. Where can I get a good deal on replacement? Or can it be repaired? Please help Model number is LS46BHPNB/XAA
You can go to Encompass or J&J electronics for the Panel. But If you have never replaced a Panel before, it is best left up to a trained Samsung tech.
Jul 08, 2009 | Samsung LN46A650 46 in. LCD HDTV
LCD Screen says ''2 missed calls''
The "[1]" (or other number) in the upper right is the number of the extension. If you have more than one extension, they will each have their own number. Unfortunately, I can't anwer your other question as I have the same problem myself.
Feb 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Remove number displayed in right hand corner in output 4
The problem was with the cable box and not the television. We unplugged box - (we'd reset it before) and the "2" was gone.
Dec 21, 2008 | Pioneer PureVision PDP-5050HD 50 in....
Number on the screen
Because the issue is occurring in multiple brands of TVs, mine is a Samsung plasma, the element that is linking all the issues together is the cable and/or SATELLITE boxes. I have actually called Samsung and they disavow any responsibility for the 2 and say that it is a cable issue. I have to agree. THE SOLUTION is to replace the cable box with a new box. I just did this last week and the 2 was gone. So if you are having this problem then i recommend trying the same thing. REPLACE YOUR CABLE BOX and/or SATELLITE TV BOX AND THE 2 GOES AWAY...at least it did for me.
Nov 10, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung sp42w4hb Rear projection
needs new convergence ships, part number stk 392-040, there is 2 of them, replace them both, also check fuses on the board, you probably need a tv repairman to fix this.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
We have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Nov 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Convergence
Replace convergence IC's.
RE-check alignment
Oct 23, 2007 | Hitachi 46F500 46" Rear Projection...
Samsung LN46A530 46 in. LCD HDTV Logo
373 people viewed this question
Henry  Thomas
Henry Thomas
