Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
I cracked the glass on my Jenn-Air 30 in. CCE3401 Electric Cooktop and need to know where to find a replacement glass - and about how much that might cost?
  • Anonymous May 03, 2009
    one crack led to another and another and another
Posted on Mar 07, 2009
  • 130 Answers
Try your local dealer. The tops can be expensive. I have seen them start at around $300.00. Check your warranty and maybe you can get it done under that. They would put like 5 years on those tops. May have to tell them that it broke when you where cooking, blame the product, not you.
Posted on Jan 28, 2009
I have a Jenn-Air CCE3401 Electric Cooktop I want to remove. How do I disconnect the wires from the cooktop? In other words, how do you get inside the cooktop to disconnect the wires? Disconnecting...
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Feb 12, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
One of the burners on my Jenn-Air electric cooktop does not turn on and get hot. 3 burners do work. Any suggestions?
the contact may be loose but most likely the burner needs to be replaced. the one you use the most usually goes first, and not getting hot enough is the common indicater of a shot burner
Jul 09, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
After cleaning- the cooktop did shortcircuit- after resetting the
since it is a glass top. there must be a crack on the surface. the cleaning liquid short out the elements. and it will stay that way till th liquid dry.
use a hair dryer to heat up the surface and see if you can see the crack. it may be a hairline crack.
once it is dry, it should turn on, unless there something else having a problem.
pleae rate the asnwer if it help in any way
thank you
Oct 16, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
569 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
