Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Igniter failure I have coleman Model # DGAT070BDD. I am starting to get a one gree flash, meaning my igniter is not working. I have turned off the power to the circuit board then back on and then the furnace will work for a while. Does my idginter need cleanning. If so how? I dare not leave the home as we get sub zero weather and my water pipes could freeze.
    President:
  • 1,214 Answers
The ignitor is probably going bad.You need to reset the cycle, then head out to get a new one before it trips cycle again.
Either that or order a new one for delivery.
If you can't leave the house to get a new one, eventually the one that is there is going to fail totally, and you won't have any heat.
When you install a new one DO NOT TOUCH THE NEW ONE WITH YOUR FINGERS. Contact and/or grasp only using the paper shield that it comes packaged in .
Posted on Jan 28, 2009
Single flash, coleman mod #dgat070bdd
Possible problem with the gas valve?
Dec 07, 2016 | Coleman Heating & Cooling
Attic fan falure hed light blinking furnace wont run
Sounds like the circuit board needs to be replaced. The exact same thing happened on my house furnace. Power went to the board, producing the flashing led, but stopped there. I believe this is what you mean?
Replace the circuit board.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Dec 04, 2013 | Coleman Heating & Cooling
When my furnace calls for heat the gas turns on and then the igniter should clicks to ignite the gas but it does not click. Does that mean that the module is bad or the igniter itself bad? The igniter has...
If the igniter is reading zero ohms that's telling you it's shorted or bad. They should range from approximately 100 to 400 ohms.
If you don't have any resistance (ohms) you won't get a voltage drop or volt reading.
Feb 07, 2010 | Coleman Propane Forced Air Heater...
I have a Coleman Evcon Mdl DGAT070BDD I am getting a trouble code 4 Flashes, which means Limit is Cycling. I replace both the control board and the limit switch, and still have the same problem.
Your heater is listed under a safety/inspection recall notice, these units have been found to overheat in certain circumstances, which can lead to a failure of the heat exchanger and the furnace. Might be the cause of your problems: http://www.dgatprogram.com/ They should do a free inspection, Good luck
Jan 03, 2010 | Tools & Hardware - Others
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
My furnace Coleman DGAT070BDD light flashes 4 times. Do you have any idea what causes that?
Trying to find out what 4 flashes on the internet will be exhausting. However if you have the manual it is explained under trouble shooting. If not, look for a wiring diagram and an error code chart will be on the diagram. Sorry I could not be more help.
Dec 15, 2009 | Coleman Heating & Cooling
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
278 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
