Question about Fuji FinePix A600 Digital Camera
Zoom error abd the lense stcked - Fuji FinePix A600 Digital Camera
  • david May 11, 2010
    If the 600 is the same lens as the 800 then possibly the plastic pin has broken off your 600 just like the 800. read my solution to the 800. Is your lens stuck or will it move? If it does not retract all the way then possibly the pin problem is the cause.
  • 6,831 Answers
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Oct 07, 2010
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
Jul 11, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom Error
this usually happens when you turn on the camera with the lense cover still on. just turn it off and remove the lense cover and turn it back on again. hope this helps.
Mar 16, 2008 | Fuji FinePix S5100 Digital Camera
Lens error
Trouble is with the motor, you have to take it to an authorize
dealer for repairs.
Dec 10, 2007 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Zoom won't work
wow alot of people have gotten this problem with the lense in this camera.
Well to cure this problem , firstly turn on the camera, ensure the lense is out ,Then GENTLY tapp on the lense in the direction that the lense feels uneven or unequal length to the outer ring (place that looks uneven).This should hopefully get the gears aligned once more.
Nov 22, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung digimax 420 zoom error
The Zoom error could be motor failure or a connector come loose. you could try the Samsung Technical Help Team Byt I suspect it is time for repair or replacement[ depending on age of the device]
May 31, 2007 | Samsung Digimax 420 Digital Camera
Fuji FinePix A600 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
