Question about Toshiba Satellite M45-S165 Notebook
M40x sometimes freez on logo
I have a model m40x.
sometimes it boots NORMAL ,
BUT sometimes it freezes on logo screen toshiba.
when I press f2 he goes to bios but after 5 to 10 seconds.
Bios works, but numbers for date and time are rolling like when I press space bar, but I don't.
I took off keybord out and it is the same. numbers rolling like if I pressed space bar.Keybord connector is clean.
Can You help me to solve this problem.
Thank You.
Zeljko.
  • 6,784 Answers
Sometimes viruses can trigger slow start ups. Try running your virus scan. also, you should make sure that your memory is working correctly. When you have a memory stick that has failed, its hard to tell if you have over 2 gigs of mem installed but, when you start it up, it will struggle during the process.
Posted on Jan 28, 2009
TOSHIBA SATELLITE L505D LAPTOP MOTHERBOARD V000185210 AMD start ok then freeze after seconds no any action what could be the reason ?
This problem occurred when your processor goes overheating due to fan and heat-sink problem.
Solution is that just clean your fan and heat-sink and then replace them. When you will start your laptop after this small service, the problem will has been removed.
Good Luck
Aug 14, 2012 | Toshiba Satellite Computers & Internet
My laptop has been freezing for a while now, I've been getting a black screen with a blue bar across the bottom of the screen where the taskbar should be. Sometimes it boots up and makes me go into...
If you have Windows Installation disk, use to repair Windows.
First go inside BIOS(Setup) with Del or F2 and change under boot options for CD/DVD to boot up first before HDD.
Put the CD in, boot from it and select repair windows once it comes up
Jul 19, 2010 | Toshiba Computers & Internet
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
Will not go beyond the boot screen at startup, pressing F2 or F12 does not respond
2 ways to try
1) Boot in safe mode F8 key while booting. if possible right click C:\ properties tools open error check tick small box to fix errors and reboot Windows on reboot will check disk for errors and fix them then restart.
2) Reinstall windows in repair mode
After all drivers etc loaded windows will ask what you want to do install, repair etc press R key for repair and follow instructions
Nov 05, 2008 | HP Vectra VL400 P3 Skt 370 Motherboard...
Freezing up
I think you need to do a power cycle. remove the battery and use tha AC adapter alone. If it boots, then thats good. U can try also booting on safe mode by pressing F8. Then re start the notebook in normal mode. If it wont works then i think u need to reinstall windows as a last resort. U need to use TOSHIBA RECOVERY DISK this time.
Sep 05, 2008 | Toshiba Satellite A105 Notebook
Equium M40X freezes
Hi, it seems your experiencing a overheat issue. At least one fan inside your PC has stopped working. The PC monitors internal heat, when the PC reaches a certain temperature it will shut down & or freeze. Chances are it's the CPU fan.
Link for your model no#
http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/jsp/SUPPORTSECTION/discontinuedProductPage.do?service=UK&DISC_MODEL=0&highlightOption=5420&com.broadvision.session.new=Yes&PRODUCT_ID=104113
Mike
Mar 29, 2008 | Computers & Internet
Won't boot up
A bit more info would be good. Did it shut down normal. can you enter bois. any messages???
Dec 06, 2007 | Toshiba Satellite M115-S1061 Notebook
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satellite M45-S165 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
