Question about HP LaserJet 3055 All-In-One Printer
Software will not reload for HP 3055 All In One Print/Scan/Fax
Before the software finish loading it goes into a loop asking the question " How do you want to download over the network or local printer. The printer is on a network, but I tried it both ways by disconnecting it from the network and still have the same problem. The problem started after a security update over the network.
  • bbghadage Feb 11, 2009
    fatal error'hpznfx01.exe. while installing HP Laserjet 3955
  • Anonymous Mar 02, 2009
    Sandmanmac,
    We understand the prompts are normal, what we are saying is that once you begin to run the disc or download files and input the appropriate information it run for a second and loops back to the same question. " How do you want to download over the network or local printer".
Have someone that actually knows what they are doing, install it for you....these prompts are normal.
Posted on Mar 01, 2009
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
I am using HP Laser Jet 3055. How can I scan in PDF format. regards
If you need to scan in PDF then you must use HP scanning software. Adobe has an exclusive deal with HP and will not open up its code to free applications like the Microsoft Scanner and Camera Wizard.
You can download the Full Software Solution (Print/Scan/Fax) for Vista 32Bit from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc
=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8
&taskId=135&swEnvOID=2093
1) Scroll down to the software section
2. Choose the appropriate Full Software Solution. (Im gussing since you are from Hong Kong that the Pacific Install will be the best one for you.)
3. Save the install to your computer
good luck, and do rate the solution if got help
Dec 04, 2010 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3005 wont install on HP laptop
HP director? the admin utility. most likely yes...Photo viewer, most likely NOT...are the 3 that can't set up differently(permissions) than the other five?
Feb 26, 2008 | HP LaserJet 3055 All-In-One Printer
Scanning documents
u can uninstall n reinstall with the help of driver cd which came with ur printer,be sure to reboot ur system after uinstallation n before installing,
Jan 27, 2008 | HP LaserJet 3055 All-In-One Printer
Scanning Problem
first of all uninstall the software completely,reboot the system,install thesoftware n connect the the printer only when asked by the software
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one
Have you installed scanning software as well as printer drivers?
Oct 21, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
