Texas Instruments Voyage 200 Calculator
Problem for Texas Instruments Voyage 200 Calculator
Voyage 200 won't turn on
By qikslvrs on Jan 28, 2009
I found my old voyage 200 from college and attempted to turn it on. I haven't used this thing in 2 years. After replacing the AA batteries it would not turn on, even when I replaced the 3V battery it's still blank. I'm gonna tear this thing apart and try to clean the contacts. Any suggestions?
Same Problem
Jan 28, 2009
-   I am in the same boat. I haven't used mine in about 2yrs pressed on....nothing....replace the batteries....nothing....i'm am despirate as i'm in a ton of engineering courses and can't really function without it or afford another one. -   cra-z-ups
Best Solution
posted on Jan 28, 2009
Very Helpful)
cra-z-ups
Rank: Wiz
Rating: 85%, 14 votes
I've fixed my Voyage 200!! I fixed it using the 3rd solution listed below. I've placed them all in there in case the one I used din't work. The funny thing is the solutions listed weren't even for the Voyage 200. I mistakenly tried the wrong one, but it worked!! I've also posted some soultions listed for the Voyage 200 just incase the others don't work and the website I found these solutions can be found here. Good Luck!!
Website:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=85103&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG1C0B48595DC76138EFAD7BAC9C1E63B698A69C9FCFEA6C84DEE9934631AC138649F2CD10EBEEF5C5E390C0B8C5F215C2F3
List of solutions that worked for me:
  1. Try a new set of batteries (including the backup battery).
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message. (worked for me!! Never actually said "Ram Cleared" just had a long box across the screen that filled up and POOF it was back!!)
  4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Voyage Solutions:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  2. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  3. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  4. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Texas Instruments Voyage 200
Questions and Unsolved Problems for Texas Instruments Voyage 200
Do you recommend Texas Instruments Voyage 200 Calculator?
Answer
Answer
my voyage 200 completely drains my batteries within 3 hours. It had not been used for few years.... (More)
Answer
TI Voyage 200 Calculator: Blank vertical lines are appearing on the screen. The solution to this... (More)
Answer
I also have the same problem, but when my calc is ON for an hour or more, then they disappear. It's... (More)
Answer
How do I create a program in the program editor that does the same as the Solve, when I have the... (More)
Answer
When I press the "On" Button, the calculator screen becomes black for a very short time... (More)
Describe your Calculators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculator Experts
Top Copier & Fax Repairmen
in , MD
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
