Question about Emerson SpongeBob SquarePants TV
Intermitent power this less than 2 yr old tv will turn on & off fine 5 to 10 time and then won't turn on again. Then you can go back to it a few days later and it will power on again. Does anyone have any suggestions for the possessed tv?
  • 979 Answers
Verify solid connection at wall outlet. Also, the front panel switches are not always making on some sets....accordianman
Posted on Oct 20, 2007
Hdmi ports om our lg tv are not working
yes you have to replace the mainboard just buy the part yourself and install it there's not much to it buy the part @ www.shopjimmy.com
Mar 02, 2013 | LG 47LW6500 47 3D LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Our 2007 Jeep Grand Cherokee randomly won't start.
change the wires that go to the starter i had the same problem fixed now with no problems
Jun 20, 2012 | 2005 Jeep Grand Cherokee
Tv restarts while we're watching it
It sounds lamp is weak in tv and need to be replaced.
If lamp has not been replaced in last 2-3 years then replace it to get tv problem fixed.
Thanks.
Jun 07, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
40H80 Toshiba Rear Projection TV
it sounds as if it is solder related, bur hard to say for sure. You ay need a service manual to actually trouble shootthe power supply and opeating circuits. I will post a lnk where you can get a service manual emailed to you
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 40H80 40" Rear Projection...
Emerson SpongeBob SquarePants TV Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
