Question about ViewSonic VX924 19" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down.?
Could you please helm me? We had the ViewSonic flat monitor for about 2 years. We shut the computer+ monitor at night by shutting off the computer via shut down on the screen and then turn off the surge protector, that shuts monitor and all. We don't shut the monitor itself because it is difficult for my husband who can't fully use his hands. When I turn on the computer in the morning, the monitor screen flashes an image for a split second and then goes blank. I noticed that the green LED power button on the monitor keeps flashing as the monitor is black. I saw someone else posted exactly the same issue on another message board !!!! So, I am not alone!! But, unfortunately there were no answer!! I press the keys, I move my mouse and eventually the monitor wakes up and stays awake, but it takes me 10 min!!! to wake it up... and I don't really know yet what keys I press and how long do I press them to wake the monitor up and I am tired to do that every morning!!! HELP!!!
  • 6 more comments
  • effzedder Nov 29, 2007
    viewsonic ve910b flashes at startup for about 10 minutes before screen can be used. just started doing this. Also does it if it has been sleeping for a while.
  • HalfzeRO Dec 07, 2007
    I am having the same problem with the ViewSonic VX924 monitor which I've had for about 2 years now. It consistently keeps flashing along with the green LED power button, and it keeps getting worse. I thought it mite of been my computer but my brother has the same monitor as i do, so I try out my monitor on his computer and it still continues to keep flashing.
  • Bradius Jan 09, 2008
    Had monitor for 2.5 years. And started having the exact same problem. It will eventually sort it self out but takes about 10 minutes. checked all cables etc, I saw a note about getting the caps done. can some one explain in more detail?
  • Matt4975 Jan 21, 2008
    I also have the same problem with my Viewsonic VX924 monitor. I purchased it new almost two years ago, and last week I started having problems with it. Specifically, I noticed that sometimes when I turned on the computer, or if I have to reboot the computer, the monitor will not turn on. Instead, the screen will remain black, while I see a "flickering" of light just around the screen perimeter. At the same time, the green power light which is normally constantly on when the power is on, blinks. The only way I can get the monitor to work when this happens, is to turn the power off and wait between 15 to 30 minutes before turning it on again. This problem is becoming more frequent. I called Viewsonic and they claim that they have never heard of this problem before. Has anybody else spoken with representatives of Viewsonic about this?
  • Anonymous Jan 29, 2008
    After the monitor has been turned off, along with my PC, if I turn on
    the monitor at the same time that I turn on the PC it will go black,
    with a slight flickering, and the power button flashes on and off. I
    can't even turn off the monitor when it's started to do that. I power
    off the PC to get the power light back on on the monitor and can then
    power it off.
    However, if I don't turn on the monitor until XP has had time to get to
    the full resolution login screen, which I can tell by the hard disk
    activity light on the PC, then when I turn on the mon it works fine.
    And doesn't flicker. This means I can't get to see the pre-boot screens
    and it's most annoying.
  • Anonymous May 13, 2008
    sdfsf
  • hudef Aug 29, 2008
    I don't know where I bought mine. Did anybody get theirs at walmart? I just want to return it and let walmart deal with this problem.
  • Anonymous Sep 26, 2008
    I am also buy this LCD 2 years ago. I have the same problems. But i live in Russia so i cant use 3 yerars warranity of ViewSonic. Too bad for me. I must buy new LCD but not from ViewSonic.
I have the same problem, my viewsonic lcd is also 2 years old, hmmm...then maybe "the" 2 years do something to them since everyone else exp the same prob after 2 yrs.
but, i find a "not so smart" solution, my lcd will turn back on whenever i unplug the power cable and then plug it back in, (won't turn on if u only press the power button)
so what i did was bought an electric switch (on-off) in the edge of my lcd's power cable, so whenever it goes blank, i can easily and quickly cut the electricity without having to bother unplugging and plug back the power cable.
hope it works for u guys
Posted on Jul 21, 2010
  • ViewSonic Master
  • 12,061 Answers
Well with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe..
Posted on Jul 30, 2007
Have a VX924, same problems. Opened it up. A few of the electrolytic caps where puffed up (like Jiffy Pop almost done) As a precaution, I replaced all 6 of electrolytics (with top quality Panasonic caps). No luck. The Bridge Rectifier was O.K. And the diodes D110 & D320 checked out OK (had to de-solder one side of diode & lift from PCB to do test) For a SWAG, I'm ordering a replacement power MOSFET (Q320), and equivalents to the Siemens BCX42 for Q6, Q7, Q8, and Q9. If it works you'll hear from me.
Posted on Jun 20, 2008
OMG I have the same freaking problem as we speak!
I am on this website because I am also searching for solution..my monitor now is blank but the power button is blinking...
I say RE CALL!
Posted on Jun 03, 2008
I have this problem with my monitor VX924. I have found it best to push the power on button on the monitor just as the pc boots up but if I miss-time this I am left with a blank screen as windows boots up normally. My monitor is just over two years old but I have had the problem for about three months now. As the problem has got worse, I have contacted Viewsonic as it has a three year guarantee. The representive also sounded surprised at this fault and asked me to try it on another pc . This confirmed the fault and also the cheap lcd monitor from the other pc worked ok on my pc. Viewsonic have agreed to collect and exchange with a replacement which I am pleased about. I think really there may be a cause for a re-call anyway, I do not think people should be taking them to bits themselves this early on.
Posted on Mar 11, 2008
I also I an issue with a Viewsonic VA720 monitor. Boot up computer and get a brief view of windows then off again. Whe you refer to the Power Supply, do you mean the power supply for the monitor or the PC? Just want to be sure I understand the resolution. What type of shop would i use for this repair? Thank you Martin - Mass
Posted on Sep 19, 2007
Monitor won't wake from sleep!!!!!!!
Sounds like you may have a bad connector. Make sure it fits snugly in the pc and the back of the monitor. If you still get no input try a different connector
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 31, 2017 | ViewSonic Computers & Internet
Viewsonic v1930wm
Sounds like the unit needs repair.
Jun 23, 2014 | ViewSonic VX924 19" LCD Monitor
I turned monitor off and now it won't come back on
For this >2 years monitor, first place to look will be the power supply section, look for caps with bulging top, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | ViewSonic VX910 19" LCD Monitor
My monitor is getting off
I have a similar issue. A search at Tomshardware web site suggests that faulty capacitors are the issue and that this is a widespread problem certainly with the VX922. Several guys on the Tomshardware post claimed that replacing the capacitors solved the problem (their units were out of warranty anyway).
Jul 20, 2009 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
View sonic flat screen monitor trouble
I have a Viewsonic Flat Screen - recently I turn it on and all I see is like tye dye colors across the monitor with a slight ghost images of windows trying to boot-up. What can I do to fix this. The monitor is about 1 1/2 year old.
Sep 08, 2008 | Computers & Internet
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Aug 26, 2008 | Scanport Computers & Internet
Waking up monitor
probably ur compuet may be in standby so u have to beat the keyboard to wake it up .
Dec 05, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
5,927 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
