Question about Dryers
Fridgidaire dryer beeping and flashing lights
The dryer has started beeping three times in a row and flashng lights for no reason. This happens all throughout the drying cycle for no rhyme or reason.
  • 1 more comment
  • crhame Jan 28, 2009
    electric, no display to see any error codes. the dryer is Fridgidaire model FEQ1442E.
    page will not load.
  • Mark Egan May 11, 2010
    Model number of the dryer?
    Is it gas or electric?
    Are there any codes given?
    President:
  • 1,214 Answers
Download the troubleshooting instruction sheet here ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134509400efs.pdf
Follow the instructions and reply back what you determine and I will help further.
Posted on Jan 28, 2009
  • Mark Egan Jan 28, 2009
    OK. Try this - www.frigidaire.com, select the Customer Service link, then select Download Manuals, then enter your Model number.
    Select the Wiring Diagram. You will get a file that is both wiring diagram and troubleshooting directions with a description of what the problems are based on front light blink codes.
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
I have a front loader fridgidaire dryer its a couple yrs old today when i put clothes in it to dry i usually hit the start button and then hit the start button again to start it but today I did it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Frigidaire Electric Dryer
Dryer beeping three times and lights flash, dryer will not start
I have this problem too, I have noticed that when this happens the moisture is high within the dryer. Usually when I open the door and let the steam out and let the dryer cool a bit it stops, but would still like to know why it really is doing this.
Feb 14, 2010 | Frigidaire FEQ1442ES Electric Dryer
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Oct 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Dryers Logo
621 people viewed this question
Top Dryers Experts
