Question about Frigidaire ATF6000ES Front Load Washer
Aggitation fin in tub has a large hole in it.
Will this affect the operation of the machine? Should it be replaced?
I fouind that I had repair coverage and have a service call scheduled. Sorry.
Posted on Jan 29, 2009
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
Had e20 error code on AEG 76650, checked the drain pump and that appears clear. tried machine on spin cycle and now makes a humming noise and doesn't spin
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
May 08, 2011 | Washing Machines
WHAT IS ERROR CODE E 20
E20 is a drain error
Jan 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Not spinning all of the water out of the clothes\/
My washer had this problem,this is what I did.I took the front panel off by prying at the top of the seam with a large flat blade screwdriver.Once the panel was off I dicovered what looked like webbing around the pump cooling fins.Someone had washed a comforter with a hole in it and some of the polyester filling spun out over the tub and got tangled around the pumps fan blade and slowed the pump down.I cleaned it out and put it back together and it's been fine ever since.
Oct 17, 2010 | GE WWSE5200B Top Load Washer
Washer wont wash on large load but will wash on medium and small i want to kwow what is going wrong it want do nothing but fill up and leak on the flooor when on large load should i replace the washer
the water pressure hose connected to the load size switch and the lower outer tub has a hole in it,remove the control panel and replace this hose,it uses water height/pressure in the tub to trigger the switch to operate the machine and the hole must be at the upper end of this hose,so it leaks before the water gets high enough to trigger the switch on a large load
Sep 08, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
ERROR CODE ON WASHER E20 MODEL NUMBER ATF6000FS0
Thank you !!
Aug 25, 2010 | Frigidaire Washing Machines
Gets to final rinse e20 come up wil not empty last rinse water out of the tub i can stop it dip the water out and it will spin out
Thank you !!
Aug 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer stops during rinse cycle and receive ER20 message, water stays in machine and spin cycle will not start.
Thank you !!
Aug 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Piece of jewlery went through holes in tub and no between tub and encloser how to get it out on a roper machine have lid up but how do i remove over sleeve on tub
pry the cap off the agitator under that you will find a large nut.remove it pull out agitator.there will be another nut remove it and the tub will come out
Aug 08, 2009 | Washing Machines
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
