SOURCE: nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
SOURCE: i have a nokia with
Security code by default is 12345, if this does not work you would need to contact nokia directly to resolve.
You may kindly note that the default security
code for all Nokia handsets is 12345. In the event the security code is changed
and you are unable to recall it, then the phone needs to be reset. You may
kindly note that the security code can be reset at any Nokia Care Center. Kindly be aware that there
will be a service provision fee associated with this service, as it is a
non-warranty procedure.
You may
kindly note, once the phone has been reset, all data in the mobile will be
lost. I recommend you take along the
proof of purchase/receipt while visiting the Nokia Care.
Good Luck.
Thanks for using FixYa.
