Question about Philips 20DV6942 20 in. TV/DVD Combo
TV won't stay on and DVD's are stuck inside
When I turn on the TV (manually or remote, same outcome), it flicks on for about two seconds and the picture is only about 3 inches at the very top of the screen with the rest of the screen black, adn then it automaticlaly turns off. I have DVD's in the dvd port built in teh tv, and i can't get them out.
You moust goyng to the service center becouse is one little problem the soft
Posted on Jul 26, 2007
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | Televison & Video
Remote won`t operate tv stuck on channel 99 w/ no signal showing
Some units have a little hole where you can insert a straightened paper clip and manually retract the DVD.
Make sure the power is turned off first.
"Your mileage may vary."
Jun 30, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Cannot get channels with remote stuck on AV2/3/4/5/6
The TV button on the remote is to select TV mode for the controller. STB, VCR & DVD do the same for their respective devices.
The A/V should select the external inputs by itself. If not try each of the Panasonic codes in turn:
0011, 0021, 0027,0029,0039,0072, 0102
Enter the codes as follows:
Press and hold TV for 3 seconds until the TV key flashes and then stays on.
Enter one of the codes (above)
TV key should flash twice. (if not go back to the beginning)
Try pressing the buttons on the controller. If all the functions do not work, try the next code.
Aug 03, 2009 | Rio Go Video DDV9475 Dual Deck VCR
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Dec 19, 2007 | Televison & Video
Philips 20DV6942 20 in. TV/DVD Combo Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
