Question about Sharp FO 2950M Plain Paper Laser Fax
Sharp fax model fo 2950m
The fax keeps saying wait a minute and does nothing else
  • 48 Answers
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
All the fax fo 2950 have the same problem it always repeating its warm up
Posted on Jan 31, 2010
What does clr toner count mean and what can i do to fix it
Go into the menu , look for reset consumables or reset counters, hit select , go down the list until you toner, hit select, clear the counter.
http://www.eserviceinfo.com/
Sep 30, 2010 | Sharp FO 2950M Plain Paper Laser Fax
I received a message that the drum needed to be replaced, so I replaced it but it still shows that message.
Now that you have new part, unplug the power for couple hours, in meantime of being uplugged, press and hold power button for 5 full slow seconds, wait half hour more and the machine should reset itself.
Jan 27, 2010 | Sharp FO 2950M Plain Paper Laser Fax
Sharp FO-3150 polygon error
You have a bad laser unit that can't be replaced.
Jan 16, 2010 | Sharp FO 2950M Plain Paper Laser Fax
Polygon error
Bad laser unit, uneconomical to repair.
Oct 22, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Recipient's say there is a black line down the middle of each page
Open the document feeder and look for wite-out on the small glass.
Sep 24, 2008 | Sharp FO 2950M Plain Paper Laser Fax
Won't accept faxes
it could be the phone cord its self some require a 4 wire setup while some require a 2 wire set up
also the jack in other room might be setup inappropriately as an out line sometime this happens
May 16, 2008 | Sharp FO 2950M Plain Paper Laser Fax
Computer insists on installing a vaild hardware over and over
uninstall, restart, and when whiz appears choose to install manually. only then insert the CD and install. should work fine now.
Feb 22, 2006 | Sharp FO 2950M Plain Paper Laser Fax
Sharp FO 2950M Plain Paper Laser Fax Logo
384 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
