Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung DLP HL-P5063W. . .no lamp!
I have a 50" Samsung HL-P5063W (2 1/2 yrs old) which does not power on. . ."Lamp" light flashes for 20 seconds and then you hear PS clicking, repeats cycle 3 times before it shuts off and all 3 lamps flash! Samsung Tech told me to replace lamp. . .they transfered me to local auth. service who told me same and sold me lamp. . .to no avail, then Samsung told me it had to be balast. . .local auth. service guy told me same, sold me balast, replaced it. . .to no avail! So $300 later. . .same symptoms. . .same problem! Local Samsung guy, who also told me, and sold me lamp and balast, wants $75 now to diagnose? I'm alittle upset with Samsung and their local service guy! Any ideas? Thanks, Matt [email protected]
  • nodirt Nov 24, 2007
    I have hln5065w, replaced the bulb and the set worked great for about a month, then it started shutting down after being on for a few hours. The lights will flash(all three) after it shuts down, I unplug and plug back in and then it trys to power up, the bulb comes on and off three or four times, you can also hear the color wheel and fan. ??????????????????????
  • janel945 Jun 13, 2008
    I am having the exact same issue. The recycling, loud fan, no picture, but there is sound. I am ordering and replacing the lamp, but was interested in determining if I should be getting any other parts while I'm at it? Would rather fix it all in one shot, rather than bit by bit.
    Please let me know what you found out and needed to do to get your system fixed, as the original message was posted almost a year ago.
Need to get this checked out my a technician who's got a samsung diagnostic computer...there's also another good resource online. search for Fix Your DLP or go to fixyourdlp.com/blog as they cover topics on Samsung DLP TVs!
Posted on Jul 26, 2007
    President:
  • 3,130 Answers
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Posted on Jul 25, 2007
I have the exact same problem, TV stared doing it about 12 days ago, I ordered and replaced the Lamp, it still does the same thing...
""Lamp" light flashes for 20 seconds and then you hear PS clicking, repeats cycle 3 times before it shuts off and all 3 lamps flash!"
Posted on Aug 12, 2008
2 Suggested Answers
SOURCE:
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
My televison keeps randomly turning off. It simply turns off for no reason. Is this the begining of something major? Please let me know -Samsung HL-p5063w
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600224B.Have a blessed one!
Mar 24, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv turns off after watching an hour - then proceeds to turn off every 15 to 20 minutes there after
Hi if your tv is a DLP or LCD and you hear clicking or like wanting to turn on ,most likely its an issue with the ballast which is the board that powers the lamp.(Discard if tv is )If you hear buzzing or spinning noises it could be you color wheel.Also check if fans are running ok or if they are dusty, clean them with an air pressure can if they are dirty.It could also be time to replace the lamp.they normally last 6000-8000 hrs if it's a Philips brand if it's na Osram lamp they will last 4000-5000 hrs 1-2 yrs.God bless you!
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture after replacing color wheel
every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
May 02, 2009 | Samsung HL-S5087W DLP TV
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
1,641 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
